opexo Posted November 28, 2012 Share Posted November 28, 2012 Hello i recently bought a '97 Escort 1.8 115hp RKC engine equipped with 60-pin ECU which for my maybe unpleasant surprise happens to be EEC-V, not EEC-IV with which im familliar more or less.. The code of the ECU written on the plastic harness plug of the case is "HOAX".I have some electrical issues, one of which is around 5,5-5,6 volts on the sensors which require 5 volt line, like TPS, ECT and MAF.For nearly a week im searching for some pinout info of this ECU because neither in Autodata, nor in Tolerance Data or in any other soft like that i have there is any information, only for EEC-V type with 104 pins. Someone told me that a problem like this may be caused by a "floating earth" or as loose eath connection as i understand it.Simmilar to EEC-IV i found that there is earth (or battery negative) on pins 20, 40 and 60 of the plug to the ECU. I fixed them with a direct wire to the battery "-" but i cant risk making other connections by guessing what is on the other pins by a simple ohm-meter via basic analogy to the eec-iv. There may be a chance in the near future to swap the engine for 2.0 from Mondeo so anyway i will need the pin-out information as this is not cowered in the available guides. So any input on any of the problems is warmly welcome. Link to comment Share on other sites More sharing options...
supersport Posted November 30, 2012 Share Posted November 30, 2012 the wiring diagram in the haynes book should help. it's waht i used on my mk5. Link to comment Share on other sites More sharing options...
