Andy W Posted March 25, 2013 Share Posted March 25, 2013 Hi Guys, I have got hold of a lower front strut brace to fit to my mk5b cab, and was just wondering if there is and helpfull hints on the easiest way to fit it ? and which holes does it actually bolt to as a quick look from underneath and couldnt see any obivious mountain points, mind you wasnt looking to hard as it was cold and wet under the car lolCheers Andy Link to comment Share on other sites More sharing options...
danny42 Posted March 25, 2013 Share Posted March 25, 2013 Hiya mate, i fitted mine a few weeks ago. It mounts to the subframe, the centre bolt is fitted directly below the steering rack, and the two outer ones fit through the holes just behind the front bolts for the lower arms. It was a little easier for me because the car is engineless atm, but i undid the steering rack bolts allowing it to be lifted slightly, thus giving room for a bolt to be dropped through. The brace can then be bolted onto this.Once that was in, the outer two could be fitted easily. Admittedly mine is a mk6, but i presume it fits in exactly the same way. If i get chance, ill try and stick a photo up for you Link to comment Share on other sites More sharing options...
Andy W Posted March 25, 2013 Author Share Posted March 25, 2013 Hiya mate, i fitted mine a few weeks ago. It mounts to the subframe, the centre bolt is fitted directly below the steering rack, and the two outer ones fit through the holes just behind the front bolts for the lower arms. It was a little easier for me because the car is engineless atm, but i undid the steering rack bolts allowing it to be lifted slightly, thus giving room for a bolt to be dropped through. The brace can then be bolted onto this.Once that was in, the outer two could be fitted easily. Admittedly mine is a mk6, but i presume it fits in exactly the same way. If i get chance, ill try and stick a photo up for you That would be great if you post up a pic Link to comment Share on other sites More sharing options...
danny42 Posted April 10, 2013 Share Posted April 10, 2013 Sorry for the delay but finally managed to get underneath and get snapping... http://i1309.photobucket.com/albums/s640/ambulance42/SN850660_zps5b4c0ad1.jpg This is where the centre bolt fits onto the subframe http://i1309.photobucket.com/albums/s640/ambulance42/SN850658_zps183ef419.jpg and this is where the arms of the brace fit. They fit in the same place on both sides. It doesn't show exactly where they mount but it should hopefully give you a decent indication. You can also see it in situ here, if you peer through all of the wires and pipes. Hope this helps Link to comment Share on other sites More sharing options...
Escort Si-130 Posted April 11, 2013 Share Posted April 11, 2013 Strange my cab doesnt have one. Unless one of the previous owners have moved it. Grrr.Need to get one of these. Link to comment Share on other sites More sharing options...
Andy W Posted April 11, 2013 Author Share Posted April 11, 2013 Cheers for the pics Danny, now all i need to sort what size nuts and bolts i need. Link to comment Share on other sites More sharing options...
