jdmsport Posted June 7, 2013 Share Posted June 7, 2013 RS2000 Engine complete with all ancils,gearbox,hubs,shafts,linkage,ecu and wiring .All the parts required to make it run and work are included from 70 £350 http://i1201.photobucket.com/albums/bb348/...zpse9cb8f60.jpg Link to comment Share on other sites More sharing options...
ShauniiBoii Posted June 11, 2013 Share Posted June 11, 2013 RS2000 Engine complete with all ancils,gearbox,hubs,shafts,linkage,ecu and wiring .All the parts required to make it run and work are included from 70 £350 http://i1201.photobucket.com/albums/bb348/...zpse9cb8f60.jpg I know you state you have everything but would this bolt straight into a mk6 1.8si without needing to buy any other bits and bobs? apart from brakes and exhaust that is. Link to comment Share on other sites More sharing options...
scottybo Posted June 11, 2013 Share Posted June 11, 2013 yes it would. u wouldnt need brakes and the like but ud be a fool not to change them Link to comment Share on other sites More sharing options...
jdmsport Posted June 14, 2013 Author Share Posted June 14, 2013 yes it would. u wouldnt need brakes and the like but ud be a fool not to change them I can chuck some brakes in no problem Link to comment Share on other sites More sharing options...
scottybo Posted June 15, 2013 Share Posted June 15, 2013 if hes giving you the manifold and cat you wouldnt even NEED to change the exhaust dude Link to comment Share on other sites More sharing options...
