antonio31 Posted October 24, 2013 Share Posted October 24, 2013 Hello, I have a problem and maybe you can help me. I have an Escort mk6 with an 2.0 16v zetec silvertop engine, with DEEP code Ecu. I have an aftermarket exhaust manifold ( stainless steel ) and the egr sistem was remove from the engine, the inlet holes were filled and i connect only the sensors ( Egr solenoid and Dpfe sensor ). I made the test and i have the following error: 332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly.Sometimes when I press the clutch the engine dies and doesn't work fine (doesn't go round). Does anyone know if the Desk or Dewy code Ecu's has this egr sistem? (or if there is another 2.0 ecu without pats, internal edis, manual transmision without the egr sistem) Or if you know how can i hack the ecu to think that the egr sistem works fine. Thanks a lot, Antonio Link to comment Share on other sites More sharing options...
