mikes-fat-arsed-estate Posted December 30, 2013 Share Posted December 30, 2013 hi all i know in modern cars the cts tells the ecu if the cars cold and to add more fuel ect & can affect mpg when they fail ect but is this the case on a 2000 tdi ford escort? or does it only tell the fan to cut in when getting to hot? thanks Link to comment Share on other sites More sharing options...
mikes-fat-arsed-estate Posted December 31, 2013 Author Share Posted December 31, 2013 Excellent cheers all Link to comment Share on other sites More sharing options...
stoo2000 Posted December 31, 2013 Share Posted December 31, 2013 Escorts usually have two temperature sensors, one for the ECU and one for the rad-fan, however it's been a long time since I've looked at a diesel so can't say for sure that it's the same. Link to comment Share on other sites More sharing options...
mikes-fat-arsed-estate Posted December 31, 2013 Author Share Posted December 31, 2013 Escorts usually have two temperature sensors, one for the ECU and one for the rad-fan, however it's been a long time since I've looked at a diesel so can't say for sure that it's the same. Cheers stoo Il look into it cheers Link to comment Share on other sites More sharing options...
Andy 3i Posted December 31, 2013 Share Posted December 31, 2013 As stoo said, one controls the fan and one tells the ecu the collant temp so it can adjust fuelling etc. Link to comment Share on other sites More sharing options...
