ESCORT_SI Posted December 8, 2003 Share Posted December 8, 2003 Hey guys, how easy is it to check drum brakes, mines making some dodgy noise and need to check it out! anyone help Link to comment Share on other sites More sharing options...
Mike C Posted December 8, 2003 Share Posted December 8, 2003 (edited) where did u spot these then, matey? on the M25? Edited December 8, 2003 by Mike C Link to comment Share on other sites More sharing options...
ESCORT_SI Posted December 8, 2003 Author Share Posted December 8, 2003 Soz, wrong board, im new to this site!!! Link to comment Share on other sites More sharing options...
Mike C Posted December 8, 2003 Share Posted December 8, 2003 Welcome to Evo, matey. someone will help u with your problem (probably Mr. Waxmonkey or someone else with such expert knowledge ) and move the thread to where it should be soon. Link to comment Share on other sites More sharing options...
M4TT Posted December 8, 2003 Share Posted December 8, 2003 i think they are on the rear axle arent they, what wrong with them buddy, bit more detail plus why spotted , if you scroll down u see problems post in there for stuff like this m8y welcome to evo as well buddy got ay pics, were ya from Link to comment Share on other sites More sharing options...
ESCORT_SI Posted December 8, 2003 Author Share Posted December 8, 2003 Cheers !, they are making a loud rubbing noise when braking !, Im from bristol and yeah i got a pic but cant seem to put it on Link to comment Share on other sites More sharing options...
Phill Posted December 9, 2003 Share Posted December 9, 2003 Buy a Haynes manual.Take the relevant bolts off, take off the drum casing and check to see if your brake shoes are worn down. If so, get new ones, grease up the relevant bits, and put it all back together again.Make sure the cylinder's not leaking too. Link to comment Share on other sites More sharing options...
Mk6 Si Ross Posted December 9, 2003 Share Posted December 9, 2003 mine regulaly has the same problem, it gets a build up inside of clumped together crusty brake dust and just needs a good scrape out once in a while Link to comment Share on other sites More sharing options...
ESCORT_SI Posted December 9, 2003 Author Share Posted December 9, 2003 Cheers for that guys, thats me busy for the weekend then Link to comment Share on other sites More sharing options...
John Posted December 9, 2003 Share Posted December 9, 2003 chock the front wheels of the vehicle. jack the back end up and support it on axle stands. release handbrake. remove wheel. remove dust cap from center of drum using a hammer and chisle or screwdriver but be carefull could break it! get a 30mm socket and a bloody long swing bar cos they will be tight and undo the hub nut. once the nut is off it's just a case then of pulling the drum off. it might need a bit of therapy cos they tend to stick on a bit but a few hits with a hammer should see it off. once off u'll probably find it's full of brake dust in there so really u should be wearing a breathing mask at this point (cheap and nasty disposable one will do just fine) get some brake cleaner, halfords or somewhere like that should sell it, give the shoes a good clean down with that then let them dry and give them a rub over with some emery cloth. do the same with the drums and u should find all is nice and quiet again refitting is a reversal of removal see i even got all the health and safety bollox in there too Link to comment Share on other sites More sharing options...
ESCORT_SI Posted December 9, 2003 Author Share Posted December 9, 2003 Cool!, thanks for the help mate Link to comment Share on other sites More sharing options...
Echos Posted December 12, 2003 Share Posted December 12, 2003 while ur at it mate just make sure u cheak ur bearings 2. Mine are almost fucked like stu pools, the just hummm all the while. Link to comment Share on other sites More sharing options...
simick1712 Posted December 13, 2003 Share Posted December 13, 2003 I seem to be having the same problem with my brakes, I'll have to have a go at doing that, cheers. I'm also finding that my handbrake seems to be really loose, would doing that help with that too? Cheers. Link to comment Share on other sites More sharing options...
ESCORT_SI Posted December 13, 2003 Author Share Posted December 13, 2003 Same here mate ! my handbreak aint working properly, as u say it seems very loose Link to comment Share on other sites More sharing options...
John Posted December 14, 2003 Share Posted December 14, 2003 hand brake adjustment - either A. prise the brake shoes outwards a couple of clicks with the drums removed or adjust the hand brake up on the cable by removing the sleve that fits around the hand brake and tightening up the 10mm nut that u will find under there. average adjustment will lead to the hand brake coming up 3 - 4 clicks Link to comment Share on other sites More sharing options...
