JIMBO Posted March 5, 2004 Share Posted March 5, 2004 I have my sub and amp and speakers running of my standard radio, My mate gave me the adapter to wire it all to the radio. But when I turn the radio or the car off there is a thud sound comming out of the sub any ideas how i can stop it making this noise. I though it may not be earthed properly but Im not sure. anybody got any ideas. CheersJimbo Link to comment Share on other sites More sharing options...
Welshboy Posted March 5, 2004 Share Posted March 5, 2004 My mates does it in his Astra. Isnt it just the power? Link to comment Share on other sites More sharing options...
JIMBO Posted March 5, 2004 Author Share Posted March 5, 2004 It might be, but im not sure. Link to comment Share on other sites More sharing options...
Scotteh Posted March 5, 2004 Share Posted March 5, 2004 think its usually the power, not 100% sure tho Link to comment Share on other sites More sharing options...
benc Posted March 5, 2004 Share Posted March 5, 2004 Sounds very much like a bad earth matey. Wack a multi meter on it and see if it drops voltage on the thud. Is it when the car is stationary or moving or what??Also...where have you earthed it to? Ben. Link to comment Share on other sites More sharing options...
JIMBO Posted March 5, 2004 Author Share Posted March 5, 2004 It happens when I turn the car or radio off matey. I to one of the panels in the boot mate. Link to comment Share on other sites More sharing options...
benc Posted March 5, 2004 Share Posted March 5, 2004 hmmm strange....well it could always be the amp remote lead that comes from the H/U to the amp. Try taking it off the amp, and gettin a bit of wire and bridging the +12V with the Remote terminal on the amp. Turn the H/U on and then off, see if it thuds then. If still does, then like i said before, check with multi-meter. If not, then just sounds like your remote amp turn on, on the H/U is a bit iffy. You'll have to wire it upto a +12 with a switch or a +12 that becomes live when ignition is on. Hope thats clear! lol Gis a shout on MSN if ya want m8, am on quite regularly. benc00@hotmail.com Ben. Link to comment Share on other sites More sharing options...
sime73 Posted March 5, 2004 Share Posted March 5, 2004 i think its just the amp m8, alot of amps do it inc mine so u have to grin and bear it Link to comment Share on other sites More sharing options...
Rich Posted March 5, 2004 Share Posted March 5, 2004 yup my amp does it too when it turns on Link to comment Share on other sites More sharing options...
benc Posted March 5, 2004 Share Posted March 5, 2004 oh if thats the case, then yea its the relays in the amp. old amps used to do this, i used to have one. nout you can do then matey. Ben. Link to comment Share on other sites More sharing options...
neil Posted March 5, 2004 Share Posted March 5, 2004 (edited) My computer speakers which are through my hifi do that when i turn it off Edited March 5, 2004 by f1web Link to comment Share on other sites More sharing options...
sextons Posted March 18, 2004 Share Posted March 18, 2004 if the remote from the standard head unit doesnt have enough amps to swtich the amp on why not put a step up relay in line will fix it straight away cost you about a quid from maplins comes with full fitting instructions as well. Link to comment Share on other sites More sharing options...
sexcort Posted March 27, 2004 Share Posted March 27, 2004 check ur connections and the rca lead if you have any, also check the positive and negatives are ok. should sort it. same thimg happened to mine - the rca s were loose, and finally if that doesnt work, check the subs hope that helps Link to comment Share on other sites More sharing options...
lottie Posted April 4, 2004 Share Posted April 4, 2004 The subs in both my cars "thud" when i turn them on..... has any 1 figured out y this happens and how to fix it yet??? Link to comment Share on other sites More sharing options...
Mike C Posted April 5, 2004 Share Posted April 5, 2004 The subs in both my cars "thud" when i turn them on..... has any 1 figured out y this happens and how to fix it yet??? read the thread and find out Link to comment Share on other sites More sharing options...
