Madmax Posted September 5, 2004 Share Posted September 5, 2004 Hey all im new to evo. Can get a 2.0Litre Turbo Focus zetec engine and all bits for a gd price, was thinkin of droppin it in me scort Its putiin out bout 220bhp Wat u all think? Shuld i go for it Link to comment Share on other sites More sharing options...
ryancollins Posted September 5, 2004 Share Posted September 5, 2004 if it will go do it mate, but also remember insurance and little things like brake upgrade Link to comment Share on other sites More sharing options...
Stu Posted September 5, 2004 Share Posted September 5, 2004 There are some differences with the black top zetec E engine.. the oil filter is in a different place.. you may want to check some fitment stuff before committing to it.. 220hp is pretty weak for a 2 litre turbo, I would assume its one of these cheapo high-compression low-boost setups, pretty crappy.. To give you a comparison, a 2.1 zetec with 8:1 compression ratio, can give you 300hp @ 1.2 bar boost on a T34 turbocharger.. using all ford parts (apart from ecu, but technically you could use eec-iv).. Link to comment Share on other sites More sharing options...
plumber60 Posted September 6, 2004 Share Posted September 6, 2004 (edited) There are some differences with the black top zetec E engineThe focus'(Foci' ) run on Zetec-S engines, not E. Edited September 6, 2004 by plumber60 Link to comment Share on other sites More sharing options...
ScottyBoy Posted September 6, 2004 Share Posted September 6, 2004 and the 2.0 esp engine uses the mtx75 gearbox (lift up reverse) where as the lower focus zetec engines use the ib5 Link to comment Share on other sites More sharing options...
Stu Posted September 6, 2004 Share Posted September 6, 2004 There are some differences with the black top zetec E engineThe focus'(Foci' ) run on Zetec-S engines, not E. I think you'll find you're wrong, it's the Zetec E. If not, what's the differences between the Zetec E and the Zetec 'S'? Link to comment Share on other sites More sharing options...
plumber60 Posted September 6, 2004 Share Posted September 6, 2004 There are some differences with the black top zetec E engineThe focus'(Foci' ) run on Zetec-S engines, not E. I think you'll find you're wrong, it's the Zetec E. If not, what's the differences between the Zetec E and the Zetec 'S'? i dont know, hmmm let me see, well for a start the 1.4 Zetec-S engine in the puma/focus has the same output as the 1.6 Zetec-E in the escort you are correct however, the 1.8 and 2.0 engines in the foci' are 'E' engines, i misread the burton power catalogue , Zetec-S - This is the baby zetec as fitted to the post 95 Fiesta, Puma and 1.4/1.6 Focus models. It has been produced in 1.25, 1.4, 1.6 and 1.7 litre capacities. These engines bare no mechanical resemblance to the Zetec-E engines Link to comment Share on other sites More sharing options...
Stu Posted September 6, 2004 Share Posted September 6, 2004 There are some differences with the black top zetec E engineThe focus'(Foci' ) run on Zetec-S engines, not E. I think you'll find you're wrong, it's the Zetec E. If not, what's the differences between the Zetec E and the Zetec 'S'? i dont know, hmmm let me see, well for a start the 1.4 Zetec-S engine in the puma/focus has the same output as the 1.6 Zetec-E in the escort you are correct however, the 1.8 and 2.0 engines in the foci' are 'E' engines, i misread the burton power catalogue , Zetec-S - This is the baby zetec as fitted to the post 95 Fiesta, Puma and 1.4/1.6 Focus models. It has been produced in 1.25, 1.4, 1.6 and 1.7 litre capacities. These engines bare no mechanical resemblance to the Zetec-E engines Indeedy.. And the main differences between the silver top and black top 'E' engines are: Oil filter location (remote), The lifters (hydraulic vs. solid), bore & stroke, and the cam cover colour The later black top is a superior engine.. we didn't go further than 470hp on this engine before we moved to development of the Duratec Link to comment Share on other sites More sharing options...
