No power won't rev over 4000prm
Turboarse
Was driving back from my mates yesterday and all of a sudden all the power has gone from my engine. Put your food down in any gear and it accelerates up to about 4000 rpm then it is as if it has reached its rev limit. It drives okay if you keep the revs low but floor it and nothing happens. Is this an engine management problem?
Unplug the sensor next to the airbox and see if it runs ok then. If it does replace it, you can do it yourself it is only one clip and it comes off. Dont leave it disconnected for too long though as it will make the engine run rich.
I'd explore all the avenues you can do yourself before taking it to Ford because they will just rip you off.
Had the same problem. Well annoying. It was my KAT. If you get it checked and it is the Kat make sure you replace it with a sports one. e.g. Powerflow do the hole system for £300 Stainless St. with a life-time warnty. (if im not mistaken)
It's gonna cost nearly as much to replace it with a standard one.
I made the mistake in replacing it with a standard one and now Im well gutted.
