willira2003 Posted August 25, 2005 Share Posted August 25, 2005 the rear windscreen heater on my escort that ive just bought hasnt worked since i bought it, i know that to replace the whole windscreen is one solution, but that costs silly money, are there any other tricks i can try to get it working? such is unplugging such and such a wire then plugging it back in the car didnt come with the owners manuel and i havent gotten round to getting a haynes manuel yet so any thoughts would be lovely! Link to comment Share on other sites More sharing options...
David Posted August 25, 2005 Share Posted August 25, 2005 Mine requently goes thru patches of 'Not Working' But its always along with the Rear wiper and Boot release. Think its a common fault, my mates Escort does the same, loose wirings my guess. Link to comment Share on other sites More sharing options...
ploppy Posted August 25, 2005 Share Posted August 25, 2005 try cleaning the contact on the bootlid and making sure that they are not damaged. if the whole windshield needs replacing, just try and source a whole new tailgate from the scrappy. if ur lucky it'll only set ya back a score. Link to comment Share on other sites More sharing options...
marsbar1973 Posted August 25, 2005 Share Posted August 25, 2005 I just purchased a new tailgate contact as mine is rather temperamental. Got it off ebay a couple of days ago. The centre pin kept getting stuck inside when opening the boot. Got it off a user called saorst for about £6 inc delivery. Does various bits. Used him before. Link to comment Share on other sites More sharing options...
Lambo Posted August 25, 2005 Share Posted August 25, 2005 I just purchased a new tailgate contact as mine is rather temperamental. Got it off ebay a couple of days ago. The centre pin kept getting stuck inside when opening the boot. Got it off a user called saorst for about £6 inc delivery. Does various bits. Used him before. <{POST_SNAPBACK}> Has this solved the problem as the middle pin on mine has always been stuck in, thought it was supposed to be??? Link to comment Share on other sites More sharing options...
marsbar1973 Posted August 25, 2005 Share Posted August 25, 2005 I just purchased a new tailgate contact as mine is rather temperamental. Got it off ebay a couple of days ago. The centre pin kept getting stuck inside when opening the boot. Got it off a user called saorst for about £6 inc delivery. Does various bits. Used him before. <{POST_SNAPBACK}> Has this solved the problem as the middle pin on mine has always been stuck in, thought it was supposed to be???<{POST_SNAPBACK}> I'll let you know when I fit it!! It's not supposed to be stuck in. Mine was too far in and not making a proper contact, so after a minor attack with a pair of pliers it popped out! Hopefully fit it in a couple of days. Link to comment Share on other sites More sharing options...
willira2003 Posted August 25, 2005 Author Share Posted August 25, 2005 cheers for all your help! especially marsbar, i'll look at the pins and contact your man. Link to comment Share on other sites More sharing options...
Al_scort16i Posted August 30, 2005 Share Posted August 30, 2005 i've replaced the pins on mine but it didn't fix the heater bit on the rear window. replaced the relay and all was ok for a couple of weeks, then it stopped again! the relay 'clicks' when i press the button on the dash so i presume that is ok, and there is continuity from one side of the window to the other so that's fine, but now i'm stuck! Link to comment Share on other sites More sharing options...
