playa Posted August 28, 2005 Share Posted August 28, 2005 i have 2 500wrms subs in a box and i need a amp for it im not rly looking to spend more than £100 on itany1 say whats a good ideai keep seeing these aussie 4 channel amps with 1800w for £50 are they worth the time of day? Link to comment Share on other sites More sharing options...
Bennys_Si Posted August 28, 2005 Share Posted August 28, 2005 i have 2 500wrms subs in a box and i need a amp for it im not rly looking to spend more than £100 on itany1 say whats a good ideai keep seeing these aussie 4 channel amps with 1800w for £50 are they worth the time of day?<{POST_SNAPBACK}> the thing is for the subs to run properly and to help the amp not being over powered, you ideally need to match the amp to the subs using the rms figure. so if you have 2 x 500rms subs then really you should be looking at an amp that is rated at 1 x 1000rms, even at 2 ohms. unless they are duel voice coil then your gonna need one that will run 1000 at 1 ohm. hop this helps Link to comment Share on other sites More sharing options...
Stu Posted August 28, 2005 Share Posted August 28, 2005 Actually, you want the amps to be more powerful than the subs. You have more chance of breaking a sub by underpowering it than overpowering it. Link to comment Share on other sites More sharing options...
playa Posted August 28, 2005 Author Share Posted August 28, 2005 so if i get one of these aussie amps that are like 1600w and wack it through 2 channels it should be fine for running the 2there on ebaystorm amps and first amps around £50 they go for wat u guys think Link to comment Share on other sites More sharing options...
