McRic Posted September 23, 2006 Share Posted September 23, 2006 I bought this to enable me to get rid of the cable running up my stairs. I missed only one point I actually still need a socket upstairs for the fax machine no point in keeping this if there has to be a cable run anyway so may aswell sell it on. BT Voyager 1055 Wireless USB Adapter with Turbo.• Works with both PCs and laptops - plugs into spare USB port.• High speed 802.11g - BT enhanced 11g up to 30% faster.• High speed USB 2 support.• Compatible with USB 1.• Compatible with Windows 2000 and XP. This costs £24.95 from Argos, brand new in box never used. box is a little rough.£15 collected or £20 posted please.Connect your computers to your wireless network from any room in your house. Enables your computer with 802.11g wireless so you can connect to a wireless network or base station and browse the broadband Internet without wires. BT's Turbo 11g technology provides file transfer between computers 30% faster than standard 802.11g. Move your computer to where it's most convenient. Place your PC anywhere in your home, and do not be restricted to where the ADSL socket is.• Plug & play installation on your computer's USB port. Supports USB2 for high speed • Windows 2000 and XP compatible. WHQL certified. Attention: Not compatible with Win98 and Me • 802.11g compliant. Also compatible with 802.11b • Turbo 11g: Normal operating speeds 30% faster than standard 802.11g 54 Mbit/s • Unlike some competitors, BT's Turbo 11g only uses a single radio channel (minimise interference) and does not rely on compression (all type of data benefit from higher speeds) • Also compatible with legacy USB 1 computers (at slower speeds up to 12 Mbit/s) • Wired Equivalent Privacy (WEP) up to 128 bit • WPA (Wi-Fi Protected Access) wireless security • Range up to 50m indoors and 250m outdoors (in ideal conditions) • Please note: This adapter is not compatible with Apple Macs You must have a wireless internet to allow this to work Link to comment Share on other sites More sharing options...
