Chris Posted February 28, 2003 Share Posted February 28, 2003 Does any1 have a engine diagram or a picture of their engine where they could point out the exact location of the idle control valve for me as i am planning on cleaning it 2moro as my cars idling badly going down to 400 rpm then up to 1200-1500 then back down again and sumtimes cuts out when cold . Link to comment Share on other sites More sharing options...
900ss Posted February 28, 2003 Share Posted February 28, 2003 mk5 plus early mk6. The valve is visible from the top attached to the offside of the manifold. Later mk6. Valve is hidden “under” nearside of the inlet manifold. Link to comment Share on other sites More sharing options...
Chris Posted March 1, 2003 Author Share Posted March 1, 2003 thanks Link to comment Share on other sites More sharing options...
JonC Posted March 5, 2003 Share Posted March 5, 2003 I know where the idle control valve is on the 1.8 zetec 1998 engine and its a b*stard to get too...also if you remove the bracket that holds the throttle cable then you can insert an allen key and adjust the idle level, i had to have mine adjusted when i put the 2ltr throtle body oni will do a pic with an arrow on it if needed Link to comment Share on other sites More sharing options...
