teh Posted August 1, 2008 Share Posted August 1, 2008 Need a how to on this please! Changing it over without loosing its gasket and fitting it with its gasket again.. Best postions to get at it and stuff. Its jack and axel ahoy this weekend for the car, going to sort the idle problem once and for all. Link to comment Share on other sites More sharing options...
speedy Posted August 1, 2008 Share Posted August 1, 2008 best way is to unbolt it from underneath using 1/4 drive ratchet and bolt it back on same way will take 5 mins if u dont have fat hands and fat arms and can fit under a car jacked up Link to comment Share on other sites More sharing options...
1pukkadeal Posted August 1, 2008 Share Posted August 1, 2008 best way is to unbolt it from underneath using 1/4 drive ratchet and bolt it back on same way will take 5 mins if u dont have fat hands and fat arms and can fit under a car jacked up Dead right there,did one today left half my skin in the engine bay, poxy location Link to comment Share on other sites More sharing options...
SaMMy125 Posted August 1, 2008 Share Posted August 1, 2008 remeber to take the battery off, its right next to the starter motor, iv hit it with the rachet many a time, I end up undoing the starter motor cables droping them down abit, then you can get right in next to the ICV for 5mins off removing the cables you save your self 30mins of struggling with icv bolt, dont bolt it back you to tight or you will crack the inlet manifold Link to comment Share on other sites More sharing options...
teh Posted August 1, 2008 Author Share Posted August 1, 2008 remeber to take the battery off, its right next to the starter motor, iv hit it with the rachet many a time, I end up undoing the starter motor cables droping them down abit, then you can get right in next to the ICV for 5mins off removing the cables you save your self 30mins of struggling with icv bolt, dont bolt it back you to tight or you will crack the inlet manifold *Blank face* I know where the battery is... i'm confused now. Thanks for the advice, I'll let you know how it goes tomorrow and wether I have a hand (and car) left! Link to comment Share on other sites More sharing options...
cherrybeard Posted August 2, 2008 Share Posted August 2, 2008 Ive got the black plastic manifold and found that lying down with feet facing rear of car and head directly underneath the idle valve works best. You may not be able to see it too clearly, but reach up and you'll instantly feel where the bolts are. As said, 5 mins doing it this way. You just cannot get your hands in through the top. I can just about manage to unplug the electrical connector from above and that is at 'wrist breaking' point! Link to comment Share on other sites More sharing options...
