KNITERIDER Posted April 14, 2009 Share Posted April 14, 2009 its on a 1.6 efi engine out of my new mk5 basically on idle the battery light flickers (i was already told this when i bought it) i know its had a new alternator so wondering why its doing this and if its the cause to (sometimes) slightly lumpy idle any ideas? Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 (edited) Check the battery voltage then reply back. Engine off and engine on readings. Edited April 14, 2009 by MC_Bob Link to comment Share on other sites More sharing options...
KNITERIDER Posted April 14, 2009 Author Share Posted April 14, 2009 il have to do it tomorrow as dad has hidden the multi meter and then il stick a reply on, if it wasnt the battery what other things could it be? and would this cause the lumpy idle? as it only seems to happen when the battery light gets brighter, when driving it virtually goes out and you can bairly see it... Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 Im thinking its more of a shorted out cable or something. Link to comment Share on other sites More sharing options...
KNITERIDER Posted April 14, 2009 Author Share Posted April 14, 2009 hmm might be or just a dodgy sensor? but would that cause the funny idleing? its fine when its been a hundred yards down the road but when started from cold (only just happned mind) if you give it a rev it can drop and cut out...im confused lol Link to comment Share on other sites More sharing options...
stoney Posted April 14, 2009 Share Posted April 14, 2009 Sounds like the rectifier in the alternator is failin mate and there fore not chargin and not havin enough powr to run the car!! or mikes fooked up the speaker wirin pmsl Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 hmm might be or just a dodgy sensor? but would that cause the funny idleing? its fine when its been a hundred yards down the road but when started from cold (only just happned mind) if you give it a rev it can drop and cut out...im confused lol For what its worth, one of the sensors on the stat failed on my white escort, caused the car to stop charging but would work when revved. Disconnect the sensor underneath, I think! and see if its better. Link to comment Share on other sites More sharing options...
KNITERIDER Posted April 14, 2009 Author Share Posted April 14, 2009 Sounds like the rectifier in the alternator is failin mate and there fore not chargin and not havin enough powr to run the car!! or mikes fooked up the speaker wirin pmsl lmao dont let him here u say that! and the alternator is new, it was changed to try and rectify the problem apparently i have the receipt etc Mc bob what exactly is the sensor under? cheers for your help guys Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 Under the thermostat! Link to comment Share on other sites More sharing options...
KNITERIDER Posted April 14, 2009 Author Share Posted April 14, 2009 now i will sound thick...wheres that...im a bit of an amaeture when it comes to car engines lmao...got a pic ? Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 Just realised its not a zetec.. So it might not apply after all =[ Link to comment Share on other sites More sharing options...
KNITERIDER Posted April 14, 2009 Author Share Posted April 14, 2009 no worries, well il test the battery off the car, then test it on the car and see what its kickin out at idle then at idle under load and that will tell me if its something to do with the alternator wont it? Link to comment Share on other sites More sharing options...
MC_Bob Posted April 14, 2009 Share Posted April 14, 2009 Yep. Link to comment Share on other sites More sharing options...
ScORTED Posted April 14, 2009 Share Posted April 14, 2009 it if is any sensor being un plugged that fixes it you've got some dodgy wiring most probably in the drivers front wing where its a pig to get too!check out the wiring on the alternator Link to comment Share on other sites More sharing options...
