dazzler24 Posted April 17, 2009 Share Posted April 17, 2009 Cars failed mot on abs,the rear sensor to the drum is broken and instead of paying £100 plus for a new sensor how do you disconect the abs,the bloke at garage said just discconect it and it will pass,how? Link to comment Share on other sites More sharing options...
Scort_CVH Posted April 17, 2009 Share Posted April 17, 2009 I take it, it is just as the light is illuminated? Link to comment Share on other sites More sharing options...
dazzler24 Posted April 17, 2009 Author Share Posted April 17, 2009 Yes the light is illuminated,but have had a look at sensor and its broke,took the bulb out of dash but didnt fool them. Link to comment Share on other sites More sharing options...
Scort_CVH Posted April 18, 2009 Share Posted April 18, 2009 Yes the light is illuminated,but have had a look at sensor and its broke,took the bulb out of dash but didnt fool them. nah it wont do, as they have to check all the lights illuminate then go out once engine is started. I'll ask the tester at work today if i remember Link to comment Share on other sites More sharing options...
StewLX Posted April 18, 2009 Share Posted April 18, 2009 I wouldn't have thought you could just disconnect the ABS since it is and integral part of the braking system. Removing the fuse (fuse 21) for it would disable the whole system maybe this is what he means? You could try the scrap yard for a new sensor shouldn't be more than a tenner.. Link to comment Share on other sites More sharing options...
Stu Posted April 18, 2009 Share Posted April 18, 2009 Just disconnect the ABS and it'll pass the MOT.. Link to comment Share on other sites More sharing options...
stoney Posted April 18, 2009 Share Posted April 18, 2009 Just disconnect the ABS and it'll pass the MOT.. Think you will find if abs is fitted to a vehicle then just disconecting it will not pass!! its fitted as standard the only way to do that is to remove abs system entirley ie valve block sensors and re route the pipes to me it easier to replace the sensor mate! Link to comment Share on other sites More sharing options...
dazzler24 Posted April 18, 2009 Author Share Posted April 18, 2009 Cheers fo the replies,guy at garage has confirmed its just easier and cheaper to replace sensor Link to comment Share on other sites More sharing options...
