tatty0001 Posted April 18, 2009 Share Posted April 18, 2009 hi the escort nds a new gearbox and was just wonderin if i need a gearbox off another 1.8 or will 1 from summet else go on. cheers Link to comment Share on other sites More sharing options...
charlie74 Posted April 18, 2009 Share Posted April 18, 2009 as far as im aware the 1.6/1.8 box is the same Link to comment Share on other sites More sharing options...
stoney Posted April 18, 2009 Share Posted April 18, 2009 as far as im aware the 1.6/1.8 box is the same Depends yes they are the same but early ones had front mount starter and late ones had rear mount also if yours is a early one then a cvh box will also fit from mk4 escort or mk5 Link to comment Share on other sites More sharing options...
ScORTED Posted April 18, 2009 Share Posted April 18, 2009 mk4 escort has a cradle, the box won't fit a mk5/6 without substantial modification any escort box with the same starter orientation will fit as long as its not a lift reverse box. (unless you have a lift reverse box then the converse is true) Link to comment Share on other sites More sharing options...
tatty0001 Posted April 19, 2009 Author Share Posted April 19, 2009 its a 96 p reg 1.8 si if tht helps... Link to comment Share on other sites More sharing options...
dutchkev Posted April 19, 2009 Share Posted April 19, 2009 most 1.6 and 1.8 gearboxs will fit Link to comment Share on other sites More sharing options...
