geordie_aaron Posted April 19, 2009 Share Posted April 19, 2009 Girlfriends old man rang me yesturday to go have a look at his fez 1.25 (zetec S shape).... its got an endura engine.... now - if you face the engine bay - the leak of this rusty/orange water is coming from the right-underside (eventually dropping off the gearbox) NOT the side of the pulleys ETC far as i'm aware the water pump is on the side of the pulleys yeah? theres NO water in the header tank but theres a load of blacky sludge in the bottom of the tank and a LITTLE on the inside of the oil filler cap - BUT the dash doesn't have temp gauge so wecan't tell if its been ran hot.... no leaks from the radiator or hoses that i can see from underneath - i think its the water pump and the gasket is on its way...... whats your opinion? getting it to the garage on Monday... Link to comment Share on other sites More sharing options...
sidrick Posted April 19, 2009 Share Posted April 19, 2009 I'd imagine the thermostat housing which leaks on these is located around that area. Link to comment Share on other sites More sharing options...
Escort_Kid Posted April 19, 2009 Share Posted April 19, 2009 Could be headgasket, if the black sludge your on about is oil in the headertank Link to comment Share on other sites More sharing options...
escort4x4 Posted April 19, 2009 Share Posted April 19, 2009 thermostat housing is that side and if its orange rusty water then i reckon his be running with in-sufficent anti-freeze.replace the seals on it and put back and keep an eye on it, you could also purchase a head gasket test die kit which will tell u in minutes if you have head gasket failure Link to comment Share on other sites More sharing options...
adamGTI Posted April 19, 2009 Share Posted April 19, 2009 problly the housing seals. its under the coil pack Link to comment Share on other sites More sharing options...
SteveB Posted April 20, 2009 Share Posted April 20, 2009 I've seen this many times. It's where the two hoses connect to the sensor block on the end of the head - underneath the coil pack. It's difficult to see the leak, but you can usually see where water has been running down the bell housing. The block is made out of alloy and reacts with the antifreeze in some way - don't know how - but you get a soft clay like build up between the hose and the spigot that pushes the hose clip away and you get the leak. Take the hoses off and scrape the clay off - clean up any large pits in the spigots with emery cloth then refit hoses using screw jubilee clips instead. Link to comment Share on other sites More sharing options...
geordie_aaron Posted April 20, 2009 Author Share Posted April 20, 2009 Just got a text off him saying "the garage have said its a plug at the back of the gearbox and they want £200 to sort it out" WHAT THE SCHIZEN?!!??! Link to comment Share on other sites More sharing options...
nick_ov_uk Posted April 20, 2009 Share Posted April 20, 2009 is it not a leaky core plug? i dont know any manual gearbox that has water in it. if it is a core plug its a easy job if you have access to it. Link to comment Share on other sites More sharing options...
geordie_aaron Posted April 20, 2009 Author Share Posted April 20, 2009 "he'd have to take the box to bits to get to it" sad thing is - he's part'exing it on Sat for a spankin new 207!!!! any temp fixes? i'm gona take the left over of my rad weld over later....failing that the raw egg trick me thinks lololol any ideas? or explanation what he means?! Link to comment Share on other sites More sharing options...
nick_ov_uk Posted April 20, 2009 Share Posted April 20, 2009 i dont know, but it sounds bizzare. if he is part exing, two bottles of rad weld Link to comment Share on other sites More sharing options...
geordie_aaron Posted April 20, 2009 Author Share Posted April 20, 2009 lol what i've been thinking, hmmmmmm Link to comment Share on other sites More sharing options...
nick_ov_uk Posted April 20, 2009 Share Posted April 20, 2009 if he is taking the box out its going to be major, just flush the system 2 bottles of rad weld and coolant then part ex it. Link to comment Share on other sites More sharing options...
