daddycool Posted March 2, 2010 Share Posted March 2, 2010 I still have prob with condensation on front window screen and the front blower dont blow much when set to warm but does when changed to front vents.2day i looked under the carpet on the passenger front and as u prob no theres another rubber bit.well that is very wet and esp under it.this is why i get condensation ovsly but wat causes this. Link to comment Share on other sites More sharing options...
dutchkev Posted March 2, 2010 Share Posted March 2, 2010 Sounds like heater matrix failure to me Link to comment Share on other sites More sharing options...
scottg17 Posted March 2, 2010 Share Posted March 2, 2010 could be a few things, Leaky wiindscreen, Blocked sunroof drains, Hole on your floorpan. Most likely will be the matrix but the others mentioned are somthing to check if the matrix is fine Link to comment Share on other sites More sharing options...
daddycool Posted March 2, 2010 Author Share Posted March 2, 2010 Any1 no how i check the matrix? where to look,wat i undo?thank you Link to comment Share on other sites More sharing options...
scottg17 Posted March 4, 2010 Share Posted March 4, 2010 best indication of the matrix leaking will be the car loosing coolant Link to comment Share on other sites More sharing options...
killalot Posted March 5, 2010 Share Posted March 5, 2010 I still have prob with condensation on front window screen and the front blower dont blow much when set to warm but does when changed to front vents.2day i looked under the carpet on the passenger front and as u prob no theres another rubber bit.well that is very wet and esp under it.this is why i get condensation ovsly but wat causes this. My gti had the dreaded water in the front passenger side,found out it was a hole behind the battery.Take battery out and your see a black plate at the back,this is what the battery buds up to.fill the kettle and pore water behind the plate look in the car with the carpet up and you should see water coming in above the ecu.Don't do what i did and cut the plate off and welded a new plate over the hole,bloody hole was only the size of a 10 pence coin,set fire to my car good job had a fire extinguisher at hand or would have lost my car.Ram loads of silicon behind the plate or that expanding foam saves a lot of hassle. Link to comment Share on other sites More sharing options...
daddycool Posted March 5, 2010 Author Share Posted March 5, 2010 brill!! ill look first thing in morningcheers Link to comment Share on other sites More sharing options...
