rodssescort Posted March 2, 2010 Share Posted March 2, 2010 fancy doing this to mine.. any one got any useful info on how to? or links to thread showing me how to? Cheers Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 2, 2010 Share Posted March 2, 2010 its like a normal silvertop rocker cover but you need to buy the new gasket and the longer bolts for it to fit and seal right Link to comment Share on other sites More sharing options...
JC Posted March 2, 2010 Share Posted March 2, 2010 IIRC the cam cover at the end is different.... I gave up on the idea as IMO a painted one looks nicer Link to comment Share on other sites More sharing options...
rodssescort Posted March 2, 2010 Author Share Posted March 2, 2010 IIRC the cam cover at the end is different.... I gave up on the idea as IMO a painted one looks nicer ive got a nice painted one on there at the mo but its getting chewed up by the throttle cable :/ any solutions? Link to comment Share on other sites More sharing options...
rodssescort Posted March 2, 2010 Author Share Posted March 2, 2010 its like a normal silvertop rocker cover but you need to buy the new gasket and the longer bolts for it to fit and seal right so i need the longer botls off the blacktop cover and a new cam cover gasket for a blacktop engine? Link to comment Share on other sites More sharing options...
SLEEMAN Posted March 3, 2010 Share Posted March 3, 2010 thats right, theres two different versions of blacktop rocker covers, you got the early blacktop version which is made of an alloy, well its lighter than steel and that one has two half moon shaped gaskets, then you got the later version blacktop which is made of plastic and that is the one you are after. you can get them from a mondeo mk2 say 1999+ and focus mk1's. tell ya what heres the part numbers for the gasket and rocker cover bolts that i recently bought from ford: blacktop rocker cover gasket: 1126120blacktop rocker cover bolts x10: 4473132 give them to ford and i think they would cost in total around £17 i think. also with the late plastic rocker cover, the cam belt cover part of the rocker cover is taller than the one of the silvertop, so you would need to cut about 10-15mm off of it so that it fits under the original cam belt cover!! Link to comment Share on other sites More sharing options...
rodssescort Posted March 3, 2010 Author Share Posted March 3, 2010 nice one cheers for your help Link to comment Share on other sites More sharing options...
escortedal Posted March 3, 2010 Share Posted March 3, 2010 IIRC the cam cover at the end is different.... I gave up on the idea as IMO a painted one looks nicer ive got a nice painted one on there at the mo but its getting chewed up by the throttle cable :/ any solutions?at the front of the engine bay,the wee clip that holds yor throttle cable, get another one from ford/scrapyard and fit it to the rear of the engine on your throttle cable,thats what i have used and it keeps the throttle cable off the rocker cver. hope this helps you. found a pic of mine,look to the rear and you can see the clip im on about and the clearance you get.http://i623.photobucket.com/albums/tt320/escortedal/007-8.jpg Link to comment Share on other sites More sharing options...
rodssescort Posted March 3, 2010 Author Share Posted March 3, 2010 IIRC the cam cover at the end is different.... I gave up on the idea as IMO a painted one looks nicer ive got a nice painted one on there at the mo but its getting chewed up by the throttle cable :/ any solutions?at the front of the engine bay,the wee clip that holds yor throttle cable, get another one from ford/scrapyard and fit it to the rear of the engine on your throttle cable,thats what i have used and it keeps the throttle cable off the rocker cver. hope this helps you. found a pic of mine,look to the rear and you can see the clip im on about and the clearance you get.http://i623.photobucket.com/albums/tt320/escortedal/007-8.jpg ahhh yea nice one! Cheers for your help! Link to comment Share on other sites More sharing options...
devman Posted March 8, 2010 Share Posted March 8, 2010 IIRC the cam cover at the end is different.... I gave up on the idea as IMO a painted one looks nicer ive got a nice painted one on there at the mo but its getting chewed up by the throttle cable :/ any solutions?at the front of the engine bay,the wee clip that holds yor throttle cable, get another one from ford/scrapyard and fit it to the rear of the engine on your throttle cable,thats what i have used and it keeps the throttle cable off the rocker cver. hope this helps you. found a pic of mine,look to the rear and you can see the clip im on about and the clearance you get.http://i623.photobucket.com/albums/tt320/escortedal/007-8.jpg That rocker cover looks mint mate, what paint did you use on it? Cheers Link to comment Share on other sites More sharing options...
