fex Posted August 15, 2010 Share Posted August 15, 2010 Hey i'm wiring up my sub and amp and iwas just wondering whether most people drill a hole to get it through to the boot or fed it through where other electrics are down the side ? fex Link to comment Share on other sites More sharing options...
kitted_escort Posted August 15, 2010 Share Posted August 15, 2010 theres a hole all ready there 4 u. its about mid of the bulkhead. just pull the gromet out n put ur cable thou it Link to comment Share on other sites More sharing options...
fex Posted August 15, 2010 Author Share Posted August 15, 2010 where is this in relation to the battery? Link to comment Share on other sites More sharing options...
shawdreamer Posted August 15, 2010 Share Posted August 15, 2010 (edited) two available grommited holes. Passenger side,behind the inner arch, comes through above the Ecu slightly outside the kick panel. Drivers side,large grommeted hole for speedo cable with sufficient space to drop behind fusebox and into kick panel. where is this in relation to the battery? the passenger side,cable can be routed straight into the wing alongside the battery then dropped down to the hole the drivers side,along the scuttle duct, through the engine bay/scuttle duct wall beneath the rear rubber seal and down 6" into the hole Edited August 15, 2010 by shawdreamer Link to comment Share on other sites More sharing options...
