rs2000van Posted October 18, 2010 Share Posted October 18, 2010 Does anybody know how i can get more out of my engine or am i best off doing a turbo conversion? Link to comment Share on other sites More sharing options...
bongo Posted October 18, 2010 Share Posted October 18, 2010 bung a escort rs turbo engine in it. Link to comment Share on other sites More sharing options...
massivewangers Posted October 18, 2010 Share Posted October 18, 2010 I know a few people with that engine in Orion Ghia's that have had pretty good results from tweaking them. You can get manifolds, cams, all sorts. Seems 125bhp is possible without going totally nuts, so long as it's a healthy engine. However, an RS Turbo conversion is probably a better value option if you're looking for a good power increase. Link to comment Share on other sites More sharing options...
rs2000van Posted October 19, 2010 Author Share Posted October 19, 2010 I know a few people with that engine in Orion Ghia's that have had pretty good results from tweaking them. You can get manifolds, cams, all sorts. Seems 125bhp is possible without going totally nuts, so long as it's a healthy engine. However, an RS Turbo conversion is probably a better value option if you're looking for a good power increase. I know what your saying mate but havn't really got the money for an rs engine then fitting and all that stuff. So thought about just making mine abit quicker and doing it in bits. How much bhp would a cam add and a manifold. Am i okay with keeping the standard air filter or would i need to change it for induction kit? I know a few people with that engine in Orion Ghia's that have had pretty good results from tweaking them. You can get manifolds, cams, all sorts. Seems 125bhp is possible without going totally nuts, so long as it's a healthy engine. However, an RS Turbo conversion is probably a better value option if you're looking for a good power increase. I know what your saying mate but havn't really got the money for an rs engine then fitting and all that stuff. So thought about just making mine abit quicker and doing it in bits. How much bhp would a cam add and a manifold. Am i okay with keeping the standard air filter or would i need to change it for induction kit? Link to comment Share on other sites More sharing options...
Markc Posted October 25, 2010 Share Posted October 25, 2010 i have a standard manifold and downpipe from a 1.6i EFI mk2 orion/mk4 escort these have larger ports and give a far better flow over the MFI parts if your interestedthe right cam, exhaust, and induction kit with a tune up will make that very poky.the cvh relies on a good working head and cam to make its power really so looking after them is the key to a good engine.also the MFI needs a good working metering unit too so a good clean out of the fuel system should help. Link to comment Share on other sites More sharing options...
