scottdow Posted December 16, 2010 Share Posted December 16, 2010 I only have one red key for my mk6 van, It does the doors and ignition. Is this the master?Where can I get another key cut? Rang my local parts place and they said £50 and it will only do the doors. Link to comment Share on other sites More sharing options...
Jordan99940 Posted December 16, 2010 Share Posted December 16, 2010 you need to get one with a chip in it and get it programmed using your master key it is explained in the ford handbook Link to comment Share on other sites More sharing options...
scottdow Posted December 16, 2010 Author Share Posted December 16, 2010 I don't have a hand book. I will do some searching. Link to comment Share on other sites More sharing options...
escrt1.4i Posted December 17, 2010 Share Posted December 17, 2010 I don't have a hand book. I will do some searching. as said the red key u have already is the master if u get another normal key cut this will be black key u can then programme yourself expect to pay about 20 pound Link to comment Share on other sites More sharing options...
Jordan99940 Posted December 17, 2010 Share Posted December 17, 2010 With the above comment you have you have to make sure it has a chip inside so don't go down to your local key cutters and get one that is 'ford looking' Link to comment Share on other sites More sharing options...
SteveB Posted December 17, 2010 Share Posted December 17, 2010 Go to Ford's with your red key. They will cut a new key for you and if you ask may come out and programme it into your ECU for you. Link to comment Share on other sites More sharing options...
akyakapotter Posted December 17, 2010 Share Posted December 17, 2010 can get them off ebay with the chip in them for around £8 blanks so just need to get the key cut Link to comment Share on other sites More sharing options...
16Vrhys Posted December 17, 2010 Share Posted December 17, 2010 Corr red keys all three fords ive had and not seen one of em lol Link to comment Share on other sites More sharing options...
scottdow Posted December 17, 2010 Author Share Posted December 17, 2010 Just phoned Timpsons (local key cutting place) £75!!will try ford tomorrow or order a blank from ebay. Link to comment Share on other sites More sharing options...
ScORTED Posted December 17, 2010 Share Posted December 17, 2010 get a chipped blank from ebay, get your local key place to cut it and program it yourself... theres instructions on here somewhere its chimpanzee levels of easy Corr red keys all three fords ive had and not seen one of em lol I've got a frickin box of red ones if you want one Link to comment Share on other sites More sharing options...
SteveB Posted December 18, 2010 Share Posted December 18, 2010 get a chipped blank from ebay, get your local key place to cut it and program it yourself... theres instructions on here somewhere its chimpanzee levels of easy The local key cutters round here won't cut chipped keys provided by the customer - they will only cut keys they provide. I guess this is in case they balls them up. Last time I had a key cut by Fords it was £15. I've posted instructions for programming loads of times - insert red key - turn ignition on and wait until red PATS light goes out - turn off and remove key - wait a few seconds until red PATS light comes back on - insert key to be programmed and turn ignition on. Done. Link to comment Share on other sites More sharing options...
etrebus Posted December 19, 2010 Share Posted December 19, 2010 just for furure you should not keep using the red key it is ment to be as a emergency spare and reprogramming only as every time it gets put in ignition it puts pats into reprogram mode was told when i worked for ford that isnt good to keep doing this Link to comment Share on other sites More sharing options...
scottdow Posted December 29, 2010 Author Share Posted December 29, 2010 Just thought I would update this.Got a blank key from ebay for about £8, took it to timpsons and they cut it for free!!Just re programmed it with infro from here.Cheers guys Link to comment Share on other sites More sharing options...
