pricey99 Posted May 28, 2011 Share Posted May 28, 2011 my car has got cossy skirts blended on the the wings so there in on way i car remove them without making a mess of the paint work.is there any way the sill can be patched up without removing the skirt?everyone is saying it will set everything on fire Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 It will set on fire. Link to comment Share on other sites More sharing options...
pricey99 Posted May 28, 2011 Author Share Posted May 28, 2011 It will set on fire. is there no way around this?can it be done form the inside removing most of the interior? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 You can get to the inner sill, but not the outer sill. All the interior would be removed anyhow, just incase of fires. Link to comment Share on other sites More sharing options...
pricey99 Posted May 28, 2011 Author Share Posted May 28, 2011 what about some kind of metal plate between the sill and skirt to deflect the heat? im just streaming off as many ideas as i can as someone is coming over tomorrow to weld it up and i really dont want to break the skirt off Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 what about some kind of metal plate between the sill and skirt to deflect the heat? im just streaming off as many ideas as i can as someone is coming over tomorrow to weld it up and i really dont want to break the skirt offSkirt has to come off mate. If you can find out where you i presume fillered to smooth it in and cut down the join you wouldn't make too much of a mess (hopefully). The heat from welding will go through it, my floor is double skinned and i had to weld some floor plates in and the weld went through the floor and you can see where it's welded inside the car. Link to comment Share on other sites More sharing options...
Scort_CVH Posted May 28, 2011 Share Posted May 28, 2011 You'll never he able to grind out the rot and weld in a new plate with that little space. Will need to do as above and cut along the join and you may get away with riveting and sealer it back on. Link to comment Share on other sites More sharing options...
pricey99 Posted May 28, 2011 Author Share Posted May 28, 2011 something tells me this is gong to be a bitch of a job lol, last thing i wanted to do was break it off. i take it spot welding wont be up to the job of it then Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 Repairs have to be seem welded. Link to comment Share on other sites More sharing options...
pricey99 Posted May 28, 2011 Author Share Posted May 28, 2011 Repairs have to be seem welded. k cheers bud. thanks for the info. think im starting to bite the bullet now. looks like its a trip to the body shop too then. suppose i best start looking at the best way to remove the skirt. the work wasn't done by me it was done by t's auto's.i'll have a feel inside the rear wheel arch and see if can tell where its blended. suppose id be wise to check the inner seal before the guy comes tomorrow Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 Repairs have to be seem welded. k cheers bud. thanks for the info. think im starting to bite the bullet now. looks like its a trip to the body shop too then. suppose i best start looking at the best way to remove the skirt. the work wasn't done by me it was done by t's auto's.i'll have a feel inside the rear wheel arch and see if can tell where its blended. suppose id be wise to check the inner seal before the guy comes tomorrowThat's alright mate. You can always do it yourself, just seen genuine Ford rattle cans used and that with some lacquer would look alright temporarily. Filler isn't too bad either, depends how much of a tart you are and how much feel you have in your hands. Why not, get the seats out and roll the carpet into the centre, that should be fine for welding the sills, may aswell, why not.Good luck mate! Link to comment Share on other sites More sharing options...
pricey99 Posted May 28, 2011 Author Share Posted May 28, 2011 yep, cheers bud.. as you said, just took the seat and plastics out, im going to roll the carpet up in a minute and leave it till tomorrow. ill let you know how i get on tomorrow. thanks for the advice mate :thumb: Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 yep, cheers bud.. as you said, just took the seat and plastics out, im going to roll the carpet up in a minute and leave it till tomorrow. ill let you know how i get on tomorrow. thanks for the advice mate :thumb:Not a problem mate Link to comment Share on other sites More sharing options...
RobMk6 Posted May 28, 2011 Share Posted May 28, 2011 Repairs have to be seem welded. Which makes me chuckle as their only glued together in the first place Link to comment Share on other sites More sharing options...
Ahmotorsport Posted May 28, 2011 Share Posted May 28, 2011 Repairs have to be seem welded. Which makes me chuckle as their only glued together in the first place I know, we had my Dads Uncles Merc 230 SL come in because the sills were gone, so we put new ones on and screwed them on (how they are out the factory) and the MOT people failed it so we argued the toss and they finally passed it. Link to comment Share on other sites More sharing options...
