3rd rear window removal
p4u1
inside the car put a flat headed screw driver into the rubber and push the rubber under the lip of the window and work around it, once the top and part of the sides have been done you should be able to pull the window out from the outside
to put it back you need a piece of cord inside the window rubber and place the bottom of the window in and inside the car pull the cord out which pulls the rubber over the lip, this is not as easy as it sounds though
