tomsy Posted November 24, 2011 Share Posted November 24, 2011 Passenger seat on my gti 3dr wont tilt forward to allow rear access lever on side lifts but seat wont tilt anyone any quick fixes thanks Tomsy Link to comment Share on other sites More sharing options...
etrebus Posted November 24, 2011 Share Posted November 24, 2011 Passenger seat on my gti 3dr wont tilt forward to allow rear access lever on side lifts but seat wont tilt anyone any quick fixes thanks Tomsyon my my 5 escort i used some bicycle brake cable and one of them white plastic electrical connecters (ones with two screws in ) threaded it on cable then threaded it through hole in lever and back around and into conector again then thread broken end (trim neat first) in connector too adjust then tighten never broke again Link to comment Share on other sites More sharing options...
tomsy Posted November 24, 2011 Author Share Posted November 24, 2011 Passenger seat on my gti 3dr wont tilt forward to allow rear access lever on side lifts but seat wont tilt anyone any quick fixes thanks Tomsyon my my 5 escort i used some bicycle brake cable and one of them white plastic electrical connecters (ones with two screws in ) threaded it on cable then threaded it through hole in lever and back around and into conector again then thread broken end (trim neat first) in connector too adjust then tighten never broke again Havn't had a good look at seat yet but how do you get inside the seat to fix cables Link to comment Share on other sites More sharing options...
etrebus Posted November 24, 2011 Share Posted November 24, 2011 Passenger seat on my gti 3dr wont tilt forward to allow rear access lever on side lifts but seat wont tilt anyone any quick fixes thanks Tomsyon my my 5 escort i used some bicycle brake cable and one of them white plastic electrical connecters (ones with two screws in ) threaded it on cable then threaded it through hole in lever and back around and into conector again then thread broken end (trim neat first) in connector too adjust then tighten never broke again Havn't had a good look at seat yet but how do you get inside the seat to fix cablesnot saying yours is the same but mine snapped at the bottom and i could reach it Link to comment Share on other sites More sharing options...
tomsy Posted November 24, 2011 Author Share Posted November 24, 2011 Passenger seat on my gti 3dr wont tilt forward to allow rear access lever on side lifts but seat wont tilt anyone any quick fixes thanks Tomsyon my my 5 escort i used some bicycle brake cable and one of them white plastic electrical connecters (ones with two screws in ) threaded it on cable then threaded it through hole in lever and back around and into conector again then thread broken end (trim neat first) in connector too adjust then tighten never broke again Havn't had a good look at seat yet but how do you get inside the seat to fix cablesnot saying yours is the same but mine snapped at the bottom and i could reach it Thanks for your advice i'll have a look at it Link to comment Share on other sites More sharing options...
