the_big_man Posted February 11, 2012 Share Posted February 11, 2012 Hiya, Found out that the ecu i was going to use was the wrong one.basically i have a 1.6 Finesse 1998 and am going to fit a fiesta rs1800 engine, which ecu am i best using??have heard that 'cult' will require huge rewiring. i've got the red key to my car. will this program only my ecu or could i could use for example a mk2 mondeo 2.0 ecu and program that using my master key or does it not work like that?? please help engine is going in as soon as ecu issue is sorted!!! Link to comment Share on other sites More sharing options...
Stu Posted February 12, 2012 Share Posted February 12, 2012 You'll want the ecu/loom/maf/injectors from a 1.8 130ps Escort, like a cabriolet. I don't have my list of codes handy right now. Link to comment Share on other sites More sharing options...
etrebus Posted February 12, 2012 Share Posted February 12, 2012 Hiya, Found out that the ecu i was going to use was the wrong one.basically i have a 1.6 Finesse 1998 and am going to fit a fiesta rs1800 engine, which ecu am i best using??have heard that 'cult' will require huge rewiring. i've got the red key to my car. will this program only my ecu or could i could use for example a mk2 mondeo 2.0 ecu and program that using my master key or does it not work like that?? please help engine is going in as soon as ecu issue is sorted!!!key chip relates to one ecu, , the red chipped key is for reprogramming other keys for the same ecu ,you can change the chips from key to key so you dont have to change locks Link to comment Share on other sites More sharing options...
SteveB Posted February 13, 2012 Share Posted February 13, 2012 You'll want the ecu/loom/maf/injectors from a 1.8 130ps Escort, like a cabriolet. I don't have my list of codes handy right now. I put the list on this thread. http://www.escortevolution.co.uk/forums/in...howtopic=128159 If you get an ecu with pats then try to get it with the red key. That way you can programme your existing keys in. If you can't get the red key, then get at least one black and get it cloned at an autolocksmith. Link to comment Share on other sites More sharing options...
Yan Posted April 17, 2012 Share Posted April 17, 2012 Hiya, Found out that the ecu i was going to use was the wrong one.basically i have a 1.6 Finesse 1998 and am going to fit a fiesta rs1800 engine, which ecu am i best using??have heard that 'cult' will require huge rewiring. i've got the red key to my car. will this program only my ecu or could i could use for example a mk2 mondeo 2.0 ecu and program that using my master key or does it not work like that?? please help engine is going in as soon as ecu issue is sorted!!!key chip relates to one ecu, , the red chipped key is for reprogramming other keys for the same ecu ,you can change the chips from key to key so you dont have to change locks I want to change the ecm in my 97 escort, but I do not have the red key of the new ecm. Will this be a problem? Aparently the PATS recognition system is located near the lock not in the ecm. Link to comment Share on other sites More sharing options...
SteveB Posted April 17, 2012 Share Posted April 17, 2012 I want to change the ecm in my 97 escort, but I do not have the red key of the new ecm. Will this be a problem? Aparently the PATS recognition system is located near the lock not in the ecm. Not correct. The transceiver ring around the lock is just a radio transmitter/receiver. Codes from the key chips are stored in flash memory inside the ECU. If you get another ECU you either need to get one or more keys with it, or get it reprogrammed by an auto locksmith. Link to comment Share on other sites More sharing options...
