Escort_lad Posted March 5, 2012 Share Posted March 5, 2012 Cars has been doing this a couple of times now seems to have a dead point when accelerating causing the car to kangaroo or stall when pulling off or moving slowly only way around this is to put the pedal to the floor and rev the hell out of it I thought i had cured it a while ago when i tightened the ground from gearbox but now doesnt cure it Help is appriciated Cheers in advance Link to comment Share on other sites More sharing options...
JC Posted March 5, 2012 Share Posted March 5, 2012 When did it last have a full service? Link to comment Share on other sites More sharing options...
AdamXR3i Posted March 5, 2012 Share Posted March 5, 2012 i had this problem recently. Was the lambda sensor but mine only did it when cruising Link to comment Share on other sites More sharing options...
Escort_lad Posted March 5, 2012 Author Share Posted March 5, 2012 Last service 2 years ago by ford and was it easy to replace Link to comment Share on other sites More sharing options...
SteveB Posted March 7, 2012 Share Posted March 7, 2012 Check the throttle position sensor. Symptom of this being faulty is trying to pull away normally results in car hiccuping, but if you ease away really slowly like you're in a queue of traffic then the car is smooth. Link to comment Share on other sites More sharing options...
Stu Posted March 7, 2012 Share Posted March 7, 2012 Have you identified if it's a certain throttle position or a certain engine load where this occurs? Is it always at the same engine speed? Link to comment Share on other sites More sharing options...
