Neil-Serenade Posted March 10, 2012 Share Posted March 10, 2012 Morning all, i think this subject may have been covered in the past so apologies if being repeated but i had a brand new genuine Ford handbrake cable, shoes and cylinders fitted about a year ago and for a while now there seems to be quite a bit of travel in the handbrake. When i had it fitted it only needed 3-4 clicks and it was solid but needs double that and even then the car can still move when i put foot slightly on accelerator. When on an incline i need to pull it up more and i can sometimes hear a creaking noise. The other day i pulled it and it needed nearly 10 clicks and the way it was pointing was ridiculous. I know it can be adjusted by the nut underneath the cover by the handbrake on the inside but my Escort is a 97 P 1.6 with discs brakes on front and drums on rear. Is there only one handbrake cable on this model because i have seen some advertised and one is for the left and one for right. Any help once again much appreciated. Cheers Link to comment Share on other sites More sharing options...
kim111156 Posted March 10, 2012 Share Posted March 10, 2012 Morning all, i think this subject may have been covered in the past so apologies if being repeated but i had a brand new genuine Ford handbrake cable, shoes and cylinders fitted about a year ago and for a while now there seems to be quite a bit of travel in the handbrake. When i had it fitted it only needed 3-4 clicks and it was solid but needs double that and even then the car can still move when i put foot slightly on accelerator. When on an incline i need to pull it up more and i can sometimes hear a creaking noise. The other day i pulled it and it needed nearly 10 clicks and the way it was pointing was ridiculous. I know it can be adjusted by the nut underneath the cover by the handbrake on the inside but my Escort is a 97 P 1.6 with discs brakes on front and drums on rear. Is there only one handbrake cable on this model because i have seen some advertised and one is for the left and one for right. Any help once again much appreciated. CheersThey have 2 cables to rear Link to comment Share on other sites More sharing options...
etrebus Posted March 10, 2012 Share Posted March 10, 2012 Morning all, i think this subject may have been covered in the past so apologies if being repeated but i had a brand new genuine Ford handbrake cable, shoes and cylinders fitted about a year ago and for a while now there seems to be quite a bit of travel in the handbrake. When i had it fitted it only needed 3-4 clicks and it was solid but needs double that and even then the car can still move when i put foot slightly on accelerator. When on an incline i need to pull it up more and i can sometimes hear a creaking noise. The other day i pulled it and it needed nearly 10 clicks and the way it was pointing was ridiculous. I know it can be adjusted by the nut underneath the cover by the handbrake on the inside but my Escort is a 97 P 1.6 with discs brakes on front and drums on rear. Is there only one handbrake cable on this model because i have seen some advertised and one is for the left and one for right. Any help once again much appreciated. Cheersyou have to slacken off the 10mm nut on the handbrake lever ,remove rear drums 4 bolts from behind clean check for ridge on drum and file off if not to bad (will need new drums if worn too much ) and adjust brakes manualy (check for slipping adjuster ) as self adjusting mechanism dosn't always work replace drums and adjust handbrake(worth while checking the threads off the nut as have known them to strip ) Link to comment Share on other sites More sharing options...
Danzetec Posted March 10, 2012 Share Posted March 10, 2012 The self adjusters on ford brake drums are a bit crap I've heard reversing up then braking hard will make the adjuster ratchet move but never managed it myself Unwind the handbrake lever adjusterRemove the drumsStrip down the brake shoes/ self adjuster etcWire brush up the adjuster mech, make sure it moves freely and clean the ratchet teeth(Check your slave cylinder whilst apart)Reassemble the shoes etcRemove lip on drum if excessiveFlick the adjuster round until the drum slides snugly onReplace hub nut or stub axle boltsTighten at lever end for desired operationCheck even aplication of braking at each click Link to comment Share on other sites More sharing options...
