KW-rscos Posted July 12, 2012 Share Posted July 12, 2012 Having a starting problem on my 1998 escort GTi, it seems to be when the car is warm, but only happened a couple of times and doesn't happen all the time/ every time the car is hit. Basically I turn the key and the fuel pump primes, all the correct lights come on, but the starter doesn't turn, but if I leave the key in that position after 5 or 10 seconds it starts to turn over then it fires up!? What could it be? Link to comment Share on other sites More sharing options...
etrebus Posted July 12, 2012 Share Posted July 12, 2012 Having a starting problem on my 1998 escort GTi, it seems to be when the car is warm, but only happened a couple of times and doesn't happen all the time/ every time the car is hit. Basically I turn the key and the fuel pump primes, all the correct lights come on, but the starter doesn't turn, but if I leave the key in that position after 5 or 10 seconds it starts to turn over then it fires up!? What could it be?i would be checking the wiring to the starter (especially the little blue wire where it connects at the starter motor)first .could be a starter motor fault or could be ignition switch Link to comment Share on other sites More sharing options...
SLEEMAN Posted July 12, 2012 Share Posted July 12, 2012 or could be signs of the starter fading off and may need changing!! Link to comment Share on other sites More sharing options...
KW-rscos Posted July 12, 2012 Author Share Posted July 12, 2012 The starter isnt that old and is a Bosch item, I will check the wiring tomorrow and report back. Link to comment Share on other sites More sharing options...
