Yule Posted August 20, 2012 Share Posted August 20, 2012 (edited) My cabby has started kangeroo'ing the last few days, so far i've just checked all the fluid/oil levels are correct & added some fuel system/injector cleaner to the petrol. it has also started idling funny as in the revs are dropping to 400-600 rpm on tick over. Any help appreciated Edited August 20, 2012 by Yule Link to comment Share on other sites More sharing options...
Stu Posted August 20, 2012 Share Posted August 20, 2012 Probably an air leak somewhere. Could also be a failed sensor. Try unplugging the MAF first and see if that fixes it. Link to comment Share on other sites More sharing options...
Yule Posted August 20, 2012 Author Share Posted August 20, 2012 Probably an air leak somewhere. Could also be a failed sensor. Try unplugging the MAF first and see if that fixes it.Will do, Link to comment Share on other sites More sharing options...
Yule Posted August 22, 2012 Author Share Posted August 22, 2012 An air leak it was, the pipe work going from the inlet had somehow worked it's way loose. It's now purring again. Link to comment Share on other sites More sharing options...
Stu Posted August 22, 2012 Share Posted August 22, 2012 Excellent. Link to comment Share on other sites More sharing options...
