daveknightyman Posted August 22, 2012 Share Posted August 22, 2012 Just baught a new clutch cable and it seems to be too small. can i move the fork for the clutch cable closer to the bell housing to make it fit? Or is there any other methods? It was orignally an SI 1.8 16v, just put everything in and its ready to go just a problem with this now, help!!! try and get a picture up soon but new to this forumthanks Dave Link to comment Share on other sites More sharing options...
Ahmotorsport Posted August 22, 2012 Share Posted August 22, 2012 Are you pulling the cable out of the sleeve? Link to comment Share on other sites More sharing options...
daveknightyman Posted August 22, 2012 Author Share Posted August 22, 2012 yeah i have, its the same size as the one that came of my si? do you think i might have just been handed the wrong cable? Link to comment Share on other sites More sharing options...
Ahmotorsport Posted August 22, 2012 Share Posted August 22, 2012 If it's the same size, it will fit. Link to comment Share on other sites More sharing options...
daveknightyman Posted August 22, 2012 Author Share Posted August 22, 2012 If it's the same size, it will fit. So the clutch cable on a 1.8 16 valve the same as one on a rs2000? i Link to comment Share on other sites More sharing options...
Ahmotorsport Posted August 22, 2012 Share Posted August 22, 2012 If it's the same size, it will fit. So the clutch cable on a 1.8 16 valve the same as one on a rs2000? iI don't know, i didn't know you had fitted an Rs2000 engine. If in doubt, order a Mk6 Escort RS2000 clutch cable. Link to comment Share on other sites More sharing options...
daveknightyman Posted August 22, 2012 Author Share Posted August 22, 2012 If it's the same size, it will fit. So the clutch cable on a 1.8 16 valve the same as one on a rs2000? iI don't know, i didn't know you had fitted an Rs2000 engine. If in doubt, order a Mk6 Escort RS2000 clutch cable. I baught a new cable for the rs2000 engine but its the exact same as the si one :S Link to comment Share on other sites More sharing options...
Ahmotorsport Posted August 22, 2012 Share Posted August 22, 2012 Then it will fit. Link to comment Share on other sites More sharing options...
Danzetec Posted August 23, 2012 Share Posted August 23, 2012 It doesn't matter which engine you have, its which gearbox that matters If you have fitted the RS2000 gearbox then you will need the same cable Link to comment Share on other sites More sharing options...
caldoofy Posted August 28, 2012 Share Posted August 28, 2012 The rs2k clutch cable and si are different did the conversion to mtx in June, found that it was necessary to release the auto tensioner on the pedal before fitting to the box counter weight then back along the bulk head ( following same routing as original cable) then pushing through the hole in the bulk head and ensuring the grommet was fully home before getting on your back and fiddling around under the dash to locate the cable on the pedal ( very fiddly ). Hope that helps. Link to comment Share on other sites More sharing options...
ekkie7 Posted August 28, 2012 Share Posted August 28, 2012 The rs2k clutch cable and si are different did the conversion to mtx in June, found that it was necessary to release the auto tensioner on the pedal before fitting to the box counter weight then back along the bulk head ( following same routing as original cable) then pushing through the hole in the bulk head and ensuring the grommet was fully home before getting on your back and fiddling around under the dash to locate the cable on the pedal ( very fiddly ). Hope that helps. Link to comment Share on other sites More sharing options...
daveknightyman Posted September 6, 2012 Author Share Posted September 6, 2012 The rs2k clutch cable and si are different did the conversion to mtx in June, found that it was necessary to release the auto tensioner on the pedal before fitting to the box counter weight then back along the bulk head ( following same routing as original cable) then pushing through the hole in the bulk head and ensuring the grommet was fully home before getting on your back and fiddling around under the dash to locate the cable on the pedal ( very fiddly ). Hope that helps. Do you know how long the cable is? as my parts distributor have given me a cable that seems to be 2 inches smaller than i need (the cable they said that would fit the rs2000 is the same size as my si one) im trying to establish if they have maybe just gotten the cable wrong but have measured roughly that the cable should be about 150 centemetres long? the tensioner is released and is still coming up 2 and half inches or so short, any ideas??? thanks dave Link to comment Share on other sites More sharing options...
