staffychance Posted September 3, 2012 Share Posted September 3, 2012 Hi Guys i need to check my wiring to the starter motor i need a photo if anyone has one. Thanks in advance. Steve Link to comment Share on other sites More sharing options...
JC Posted September 3, 2012 Share Posted September 3, 2012 Follow big red wire from battery down to back of engine... Guessing you may have a starting issue? Check the connectors, I had a dodgy connector, caused me loads of issues Link to comment Share on other sites More sharing options...
Jordan99940 Posted September 4, 2012 Share Posted September 4, 2012 Follow big red wire from battery down to back of engine... Guessing you may have a starting issue? Check the connectors, I had a dodgy connector, caused me loads of issues http://www.evo-host.co.uk/getimg/26052.jpg .Check Earth straps all over engine bay/ Link to comment Share on other sites More sharing options...
staffychance Posted September 4, 2012 Author Share Posted September 4, 2012 May starter will not engage to the point of burniong starters out, i have tried two spares that worked and its killed them. Your starter looks different to mine. Link to comment Share on other sites More sharing options...
staffychance Posted September 4, 2012 Author Share Posted September 4, 2012 May starter will not disengage to the point of burniong starters out, i have tried two spares that worked and its killed them. Your starter looks different to mine. Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 4, 2012 Share Posted September 4, 2012 There are different starters for front and rear mounted versions.sounds like you have a high resistance in the circuit somewhere. Link to comment Share on other sites More sharing options...
waynegc123 Posted September 4, 2012 Share Posted September 4, 2012 May starter will not disengage to the point of burniong starters out, i have tried two spares that worked and its killed them. Your starter looks different to mine. I also had the issue of the started just running away. If I remeber correctly it was the cables that was damaged from the alternator to the started. I think the signal cable from the alternator and the charging cable tocuhed. Link to comment Share on other sites More sharing options...
staffychance Posted September 4, 2012 Author Share Posted September 4, 2012 OMG its done Moving the live from alternator across to the same connector as the battery seems to help.......yes Im a dick i know. Thanks for all the help and advice guys. If you put alternator to exciter connector your start will constantly run,start to smell cut it self out, if you repeat this your starter will die fast. Link to comment Share on other sites More sharing options...
