roboboyo Posted September 17, 2012 Share Posted September 17, 2012 Hi guys How easy is it to install a 2ltr fuel rail and injectors??? i have a 2ltr engined escort, but its still running on 1600 managment, i have a 2.0 deep ecu, and maff, but not familier(spell check) with fuel rails and injectors is there a how to guide for this, (sorry if your shouting, this is so easy ) i need schooling Link to comment Share on other sites More sharing options...
Ahmotorsport Posted September 17, 2012 Share Posted September 17, 2012 (edited) Doddle fella. Remove fuel lines and two 8mm bolts IIRC hold it in place, then pull it out. Just to add, check all the seals are still on the injectors when you pull 'em out. Edited September 17, 2012 by Ahmotorsport Link to comment Share on other sites More sharing options...
JC Posted September 17, 2012 Share Posted September 17, 2012 very easy, 4 x8mm bolts and clips to the fuel rail, i recommend using new seals though Link to comment Share on other sites More sharing options...
roboboyo Posted September 17, 2012 Author Share Posted September 17, 2012 very easy, 4 x8mm bolts and clips to the fuel rail, i recommend using new seals though thanks alot guys do they slot into the inlet mani??? Link to comment Share on other sites More sharing options...
JC Posted September 17, 2012 Share Posted September 17, 2012 ^ yes fuel rail on the 2.0 is the same as the 1.6, but i never like removing injectors from the rail itself as snapped one once before, and its easier just to swap the injectors in the rail Link to comment Share on other sites More sharing options...
roboboyo Posted September 17, 2012 Author Share Posted September 17, 2012 ^ yes fuel rail on the 2.0 is the same as the 1.6, but i never like removing injectors from the rail itself as snapped one once before, and its easier just to swap the injectors in the rail Cheers John Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 18, 2012 Share Posted September 18, 2012 ^ yes fuel rail on the 2.0 is the same as the 1.6, but i never like removing injectors from the rail itself as snapped one once before, and its easier just to swap the injectors in the rail Just like I keep banging on about Digi Dials, how easy is it to change all the seals? Might as well cant be expensive. Link to comment Share on other sites More sharing options...
JC Posted September 18, 2012 Share Posted September 18, 2012 ^ yes fuel rail on the 2.0 is the same as the 1.6, but i never like removing injectors from the rail itself as snapped one once before, and its easier just to swap the injectors in the rail Just like I keep banging on about Digi Dials, how easy is it to change all the seals? Might as well cant be expensive. The ones you had, the O rings / seals on the injectors were replaced when the injectors were refurbed (Cost ~£60) the seals / gasakets on the end of the injector onto the manifold weren't Link to comment Share on other sites More sharing options...
Naylor2006 Posted September 19, 2012 Share Posted September 19, 2012 ^ yes fuel rail on the 2.0 is the same as the 1.6, but i never like removing injectors from the rail itself as snapped one once before, and its easier just to swap the injectors in the rail Just like I keep banging on about Digi Dials, how easy is it to change all the seals? Might as well cant be expensive. The ones you had, the O rings / seals on the injectors were replaced when the injectors were refurbed (Cost ~£60) the seals / gasakets on the end of the injector onto the manifold weren't The latter I replaced, we just put the best conditioned 2.0 injectors in in the end, cause I had two sets, forgot which ones they were. Link to comment Share on other sites More sharing options...
