VanMan_Jas Posted October 5, 2012 Share Posted October 5, 2012 I have recently replaced the 1.8 TD engine (intercooled) in my van as the old one was knackered. I used the fuel pump and solenoid from the original engine to keep PATS happy (the solenoid on the pump is coded to the key / ECU / PATS). This is the third time I have replaced the engine, following the same process, with no issues on the previous attempts. Hand primer pump is primed. When I turn the key to ignition, I hear the solenoid on the fuel pump clicking fast, approximately 10 times. I think this is normal. When the key is turned to start the engine, nothing at all happens. No cranking, no starter motor, nothing. There is one connector I cannot find a plug for, that I hope is the cause of my starting issues. It must go somewhere: It comes from behind the passenger headlight and is long enough to reach to the gearbox side of the engine block. It has 2 thick wires, one purple, one black:http://i392.photobucket.com/albums/pp2/ax_jas/Escort%20Van/20121004_204122.jpgThe loom has a label on it: http://i392.photobucket.com/albums/pp2/ax_jas/Escort%20Van/20121004_204148.jpgBB 96AG-8C290 Any ideas what this plug is and where it goes to? Once that is out the way I can start considering the fuel pump / PATS etc. Any ideas? Can someone with a 1.8 TD check their loom for me? Link to comment Share on other sites More sharing options...
etrebus Posted October 5, 2012 Share Posted October 5, 2012 (edited) they look big enough to be starter solenoid wires stick a tester in the purple end and see if it lights when the ignition is in the crank position Edited October 5, 2012 by etrebus Link to comment Share on other sites More sharing options...
VanMan_Jas Posted October 8, 2012 Author Share Posted October 8, 2012 Ok, spent an hour looking at it today.Turns out the connector is to the cooling fan. The reason I couldnt work that out initially is because I havent refitted the cooling fan. LOL. totally fogot about it. So that is not the cause of my starting probem. However, after a bit of work with the multimeter, and going back to basics, I think the issue is just a faulty starter motor.I get 12v at the large wire on the starter ad when ignition is switched I also get 12v at the smaller wire that should kick the starter solenoid. However, nothing happens.Either the starter solenoid is jammed or the whole starter is knackered.Either way, I have a spare starter motor I will fit shortly and she will hopefully turn over. If it was an immobiliser issue, I think PATS cuts out the starter motor and fuel pump but im not 100% on that. More updates soon... Link to comment Share on other sites More sharing options...
DaweV6 Posted October 8, 2012 Share Posted October 8, 2012 What's the red LED on a dash doing ? Is she happy ? Link to comment Share on other sites More sharing options...
VanMan_Jas Posted October 8, 2012 Author Share Posted October 8, 2012 What's the red LED on a dash doing ? Is she happy ?Led goes out once ignition is turned on. Flashes when ignition off and key removed.I guess that means shes happy? Jas Link to comment Share on other sites More sharing options...
VanMan_Jas Posted October 15, 2012 Author Share Posted October 15, 2012 I have changed the starter motor and she now turns over and starts. Engine would cut out as if there was a fuel issue.I tracked this down to the fuel primer pump that houses the fuel filter. Fitted a spare one I had in my garage and the engine now starts and runs!! Just got to fit a new radiator top hose and bleed the coolant system and shes ready for a test drive. Link to comment Share on other sites More sharing options...
