Yozman2000 Posted October 8, 2012 Share Posted October 8, 2012 does anyone have any ideas bout this? if i drive around a long left hand bend (like a slip road) the fuel pump cuts out until the car straightens out.i have replaced the fuel filter and it has made no difference. can anyone help? Link to comment Share on other sites More sharing options...
Stu Posted October 8, 2012 Share Posted October 8, 2012 How do you know the fuel pump is cutting out? Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 How do you know the fuel pump is cutting out?thats what it feels like, what else could it be? Link to comment Share on other sites More sharing options...
Stu Posted October 9, 2012 Share Posted October 9, 2012 Fifty other things. Could be a dodgy wiring loom. Could be having no fuel in the tank. Could be lots of things! Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 Fifty other things. Could be a dodgy wiring loom. Could be having no fuel in the tank. Could be lots of things!it does it with half a tank of fuel! and the fuel pump is on the right hand side of the tank? Link to comment Share on other sites More sharing options...
Stu Posted October 9, 2012 Share Posted October 9, 2012 I'd get a qualified mechanic to at least tell you what the actual behaviour is and then either you or he can look at diagnosing it. Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 I know when my engine isnt getting fuel, i was asking on here incase there was a common problem before i start stripping the tank off the car, may be there are some helpful people on here Link to comment Share on other sites More sharing options...
sidrick Posted October 9, 2012 Share Posted October 9, 2012 Oooh, you're gonna last long Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 Oooh, you're gonna last long yea well whats the point of having a forum like this if the best answer someone can give is "take it to a mechanic" Link to comment Share on other sites More sharing options...
Stu Posted October 9, 2012 Share Posted October 9, 2012 I know when my engine isnt getting fuel, i was asking on here incase there was a common problem before i start stripping the tank off the car, may be there are some helpful people on here You don't know when your engine isn't getting fuel. All you know is that the engine loses power when you corner. Like I kindly went out of my way to tell you, lots of things can cause that SYMPTOM. If you don't like that answer, then have fun removing your fuel tank. Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 I know when my engine isnt getting fuel, i was asking on here incase there was a common problem before i start stripping the tank off the car, may be there are some helpful people on here You don't know when your engine isn't getting fuel. All you know is that the engine loses power when you corner. Like I kindly went out of my way to tell you, lots of things can cause that SYMPTOM. If you don't like that answer, then have fun removing your fuel tank.its not "loss of power" the engine cuts out until it straightens up, so if its not fuel starvation what is it?if i take it to a mechanic they will only replace the fuel pump first anyway so just pissing money up the wall eh? Link to comment Share on other sites More sharing options...
Stu Posted October 9, 2012 Share Posted October 9, 2012 It seems you have already made your mind up with a) what's wrong and b) what anyone else will do to fix it. Stop wasting our time. Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 It seems you have already made your mind up with a) what's wrong and b) what anyone else will do to fix it. Stop wasting our time.STOP WASTING OUR TIME!! your the one answering the posts with useless comments! just so you can look good because you have replied to as many posts as possible! I dont know what causing it but i know enough to know when my engine aint getting fuel. think im wasting your time dont reply to my posts, and perhaps someone who has had the same problem may reply.ps you cant go though life being a gimp, get off the internet and get a life, nothing nice to say then go away Link to comment Share on other sites More sharing options...
Stu Posted October 9, 2012 Share Posted October 9, 2012 Listen sunshine, don't get your knickers in a twist because someone doesn't tell you what you want to hear. How about this then? I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help? Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 Listen sunshine, don't get your knickers in a twist because someone doesn't tell you what you want to hear. How about this then? I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help?"sunshine?" firstly its not that you have told me something i dont wanna hear! just seems like you got up on the wrong side of bed and wanna pee as many people as possible off.i asked for help with a topic and expect someone to reply with "yes Ive had this problem before try this"now then faulty muffler bearing sounds more helpful, for this i thank you but the full exhaust system has been replaced (from manifold to decat to backbox) so i doubt this being the problem Link to comment Share on other sites More sharing options...
