Ahmotorsport Posted October 9, 2012 Share Posted October 9, 2012 (edited) I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help? Edited October 9, 2012 by Ahmotorsport Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 Link to comment Share on other sites More sharing options...
danj8608 Posted October 9, 2012 Share Posted October 9, 2012 If it could be a wiring problem then why would it not do it on right hand bends either ? Other than the exhaust system it has a superchip. Any ideas what it could be ? wether or not it could be 50 other things.. I thought it could be an issue with the fuel pump not getting enough fuel as soon as you take some lock off the steering its fine. Last resort will be a mechnic Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 If it could be a wiring problem then why would it not do it on right hand bends either ? Other than the exhaust system it has a superchip. Any ideas what it could be ? wether or not it could be 50 other things.. I thought it could be an issue with the fuel pump not getting enough fuel as soon as you take some lock off the steering its fine. Last resort will be a mechnicyup last resort lol Link to comment Share on other sites More sharing options...
sidrick Posted October 9, 2012 Share Posted October 9, 2012 Muffler bearing, lol. Have you tried jacking one side of the car while it's idling? My money would be on a connection on or around the pump itself. Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 Muffler bearing, lol. Have you tried jacking one side of the car while it's idling? My money would be on a connection on or around the pump itself.if it is its between the car and the pump not in the car ( ive had it stripped )may try jacking it up thanks Link to comment Share on other sites More sharing options...
sidrick Posted October 9, 2012 Share Posted October 9, 2012 Personally, if I thought there could be an issue with my fuel pump, then I'd start with the pump itself and work back from there. In and around the tank is pretty much exactly where you don't want poor electrical connections. As far as you're aware, is it the original fuel pump? Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 9, 2012 Author Share Posted October 9, 2012 as far as i know yes it is Link to comment Share on other sites More sharing options...
Naylor2006 Posted October 9, 2012 Share Posted October 9, 2012 My old fuel pump was doing this, hard left and it wouldn't cut out but it would starve the fuel, didn't happen on right bends, was was happening was the g pulling the pump one was causing the 12v to come loose. Link to comment Share on other sites More sharing options...
MCCORNY11 Posted October 9, 2012 Share Posted October 9, 2012 I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help? http://www.evo-host.co.uk/getimg/30091.jpg Link to comment Share on other sites More sharing options...
Ahmotorsport Posted October 9, 2012 Share Posted October 9, 2012 I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help? http://www.evo-host.co.uk/getimg/30091.jpgThey're a right pain in the arse to fit, it's a mare finding those left handed screwdrivers. Also got to go on dead level and last time i forgot to put bubbles in my spirit level.... :roll::roll: Link to comment Share on other sites More sharing options...
p4u1 Posted October 9, 2012 Share Posted October 9, 2012 I had exactly the same symptoms as you due to a faulty muffler bearing. Does that help? http://www.evo-host.co.uk/getimg/30091.jpgAye I've never seen that before :l Lol must check mine Link to comment Share on other sites More sharing options...
Yozman2000 Posted October 10, 2012 Author Share Posted October 10, 2012 My old fuel pump was doing this, hard left and it wouldn't cut out but it would starve the fuel, didn't happen on right bends, was was happening was the g pulling the pump one was causing the 12v to come loose.defo gonna look at that cheers mate Link to comment Share on other sites More sharing options...
demented Posted October 23, 2012 Share Posted October 23, 2012 Don't know whether your issue been resolved. However, I had similar issue on Escort, it would cut out slightly on left turns, occasionally on long bends. Turned out, the area behind battery had corroded, so the battery was not being held as secure as it should be, although when I rocked the battery by hand, it felt secure. On left turns the battery would slide slightly to the left, enough so the edge of the live terminal which slightly protruded from under the plastic battery cover would catch a bolt of the bonnet hinge and short out briefly. The engine would hesitate, felt like running out of fuel. Link to comment Share on other sites More sharing options...
