A few problems with my 1994 escort cab
daveyroo
Hi, I'm about to sell my car and use the money to fix up this old escort we've had since 1994. But there are a few things wrong with it and I'm not sure what the problems might be, so any help would be greatly appreciated!
In case it helps identify problems, it's a 1.8l Si 1994 cabriolet (from memory)
Firstly, the battery keeps draining, but I think this is because the glove box is broken, it keeps falling open and on the inside it says if the glove box is left open the battery will drain.
Secondly, 5th gear keeps popping out, I have no idea what this could be would it require a new gear box? It's okay if you drive along holding the stick in gear.
I'm sure there is something else but I just can't remember at the moment! Thanks for any help
