jjcool Posted March 31, 2013 Author Share Posted March 31, 2013 If it's been mapped then why ask if you need to adjust the cold start mapping? i asked because when it was running previously it was very hard to start the car when it was cold and ierratic idling and it would be ok once warmed up. i thought it maybe of been the cold start settings in megasquirt however after doing a mini service all seems fine. just the white smoke issue now. also i dont think k reg escorts had the OBD port as i was going to plug in my eithos just to double check any fault codes but i dont think k reg escorts had them. Link to comment Share on other sites More sharing options...
Stu Posted March 31, 2013 Share Posted March 31, 2013 The diagnostics port won't be doing anything if you're running Megasquirt. Servicing isn't going to fix a cold start issue. It's more than likely because it's a bit warmer now than it was a week ago. Link to comment Share on other sites More sharing options...
jjcool Posted April 1, 2013 Author Share Posted April 1, 2013 The diagnostics port won't be doing anything if you're running Megasquirt. Servicing isn't going to fix a cold start issue. It's more than likely because it's a bit warmer now than it was a week ago. ts a real shame megasquirt dont show fault codes i have noticed regarding the white smoke theres quite a bit of water in the exhaust this is maybe due to the fact the cars been sitting for along time. Link to comment Share on other sites More sharing options...
