james08 Posted April 4, 2013 Share Posted April 4, 2013 ive just swapped the engine on my van to a tdi and now the gearbox doesnt like staying in 5th, if i dont hold it in 5th it will pop out on corners or when braking any got any ideas? Link to comment Share on other sites More sharing options...
demented Posted April 4, 2013 Share Posted April 4, 2013 Think slight adjustment needed to the selector rod/linkage underneath gear lever. I had similar on my Escort 1.8 when I replaced thevgearbox but think it was 3rd gear and reverse not 5th. Its a while ago now but from underneath the car, I think I loosened the linkage clamp and from inside, moved gear lever to either left of right slightly, which caused the linkage rod to rotate. It can all be done from underneath. If that doesn't cure the problem, it could be an issue with the selector shaft retaining pin which holds the shaft in the selected gear. I believe this can be replaced without stripping the gearbox, there are two shaft retaining pin bolted into gearbox housing. In the following link, one can be seen partially removed, shown in 12th photo. http://www.projectpuma.com/viewtopic.php?t=2519 Link to comment Share on other sites More sharing options...
james08 Posted April 4, 2013 Author Share Posted April 4, 2013 ill have a mess tomorrow if i get a chance Link to comment Share on other sites More sharing options...
Escort Si-130 Posted April 5, 2013 Share Posted April 5, 2013 Get it up on axle stands, and adjust the selector. I did this with the engine on to check the gearing. But was very careful whilst it was on stands and wheels were not touching the ground. I went through the gears as though I was driving. It was then easy to make any adjustments by switching the engine off after, then loosening the lever clamp and then tightening it to get the optimal gear change. Link to comment Share on other sites More sharing options...
