marshy Posted April 17, 2013 Share Posted April 17, 2013 hey guys.. not mine but my old mans.. as title really...1.6 mk6 95 efi inlet ... its trying to stall itself on idle.. and always hunting.. ive changed the TPS and cleaned the ISCV to no joy also to me (and it could just be me!) its sounds as tho theres a air leak.. soooo.. ive tried caputuring it in the video ive uploaded (if it works!)just in case any of you knowledgeable lot may be able to point me in the right direction and/or confirm my guesswork!! thanks in advance video Link to comment Share on other sites More sharing options...
scottybo Posted April 17, 2013 Share Posted April 17, 2013 i would..- clean the maf out and the.connectors. my old efi 1.6 broke the little clip holding the maf in so it kep coming unplugged and running like crap- check to see shes firing on all plugs- check blocked fuel filter- check the inlet for any loose hoses etc does it run rough all the time or only at idle? Link to comment Share on other sites More sharing options...
marshy Posted April 17, 2013 Author Share Posted April 17, 2013 when driving if he changes gear its trying to stall when clutch is down..general cruising its fine.. couldnt see no problems with the maf altho it didnt stall when disconnected..plugs afaik its had new plugs recently...ill check all hoses on the inlet and fuel filter tho Link to comment Share on other sites More sharing options...
Ahmotorsport Posted April 17, 2013 Share Posted April 17, 2013 (edited) Give the throttle body a good clean, maybe a Lambda clean too (If it's got one?) Edited April 17, 2013 by Ahmotorsport Link to comment Share on other sites More sharing options...
etrebus Posted April 17, 2013 Share Posted April 17, 2013 worth checking for a split pipe especially under the coil pack if you say you can hear an air leak Link to comment Share on other sites More sharing options...
scottybo Posted April 20, 2013 Share Posted April 20, 2013 has this been resolved dude? Link to comment Share on other sites More sharing options...
opexo Posted April 20, 2013 Share Posted April 20, 2013 Check PCV valve too.You can always hook a voltmeter (analog preferably) with 2 volts scale or even 1 volt better between battery negative and HEGOs signal wire to check what the engine's doing.Clean the MAF just in case. I had the same rough idle on my GTI and it was the PCV valve which is the same as air leak issue. The pipe is plugged now (the one to the intake, the other from the PCV is free), breathing only from the one between the head cover and air filter box so no more intake contamination too. It's like that since November and no issues. Link to comment Share on other sites More sharing options...
marshy Posted April 28, 2013 Author Share Posted April 28, 2013 No it hasn't been sorted yet I've checked all hoses etc but couldn't find nothing.. So I've told him to get it read on a diagnostics as we could change parts forever and still not find owt.. Link to comment Share on other sites More sharing options...
