roboboyo Posted June 18, 2013 Share Posted June 18, 2013 (edited) ok guys, I'm at the end of my road with this problem, symtoms, car runs rough from time to time, with splurts and coughs on heavy load, and after going down through the revs, she drops rights down, hunts, and stalls The Things Ive done are, 1) new iscv2) new lambda sensor3) new maff sensor4) new tps5) new plugs6) new ht leads7) i cleaned the tb, and re sealed, checked for air leaks what next, please help if you can, has anybody been down a similar path??? Edited June 18, 2013 by roboboyo Link to comment Share on other sites More sharing options...
Stu Posted June 18, 2013 Share Posted June 18, 2013 Clarify if 'new' means you bought a brand new one from Ford? Link to comment Share on other sites More sharing options...
roboboyo Posted June 18, 2013 Author Share Posted June 18, 2013 Clarify if 'new' means you bought a brand new one from Ford? new, as in from ebay, brand new, from highly recommended sellers Link to comment Share on other sites More sharing options...
scottybo Posted June 18, 2013 Share Posted June 18, 2013 i did recommend a compression test a few weeks back Link to comment Share on other sites More sharing options...
roboboyo Posted June 18, 2013 Author Share Posted June 18, 2013 i did recommend a compression test a few weeks back was tested already, fogot to mention that, i was all day with the mechanic today, and he seems to think its coming from around the inlet manifold, he wants a 2nd day to look at it, but i want to know if anybody had similar issues that they resolved, like a pcv valve?? Link to comment Share on other sites More sharing options...
scottybo Posted June 18, 2013 Share Posted June 18, 2013 if theres a leak between the intake manifold and the head it will run like sh!t so that makes sense Link to comment Share on other sites More sharing options...
roboboyo Posted June 19, 2013 Author Share Posted June 19, 2013 if theres a leak between the intake manifold and the head it will run like sh!t so that makes sense quick school lesson needed, where does the vacuum pipe go into the head?? Clarify if 'new' means you bought a brand new one from Ford? new, as in from ebay, brand new, from highly recommended sellers got a mechanic lined up to preform a live data test, hopefully it will id my problem Link to comment Share on other sites More sharing options...
