roboboyo Posted July 1, 2013 Share Posted July 1, 2013 how easy is it to remove the plastic inlet manifold on mk6 zetec? Link to comment Share on other sites More sharing options...
SLEEMAN Posted July 1, 2013 Share Posted July 1, 2013 Without getting your hands injured not a hope in hell lol you have to remove the throttle body and probably best to remove fuel rail, disconnect all the plugs and pipes, then it's two nuts I think they are either 10 or 13mm nuts either side on manifold studs then I think from guessing its about 7 or 8 10mm bolts the bottom row you can get from but some others you need to get under the car for! Then slide back and wiggle it out! Link to comment Share on other sites More sharing options...
supersport Posted July 1, 2013 Share Posted July 1, 2013 as above, i can get mondeo ones out without breaking them. Link to comment Share on other sites More sharing options...
