blacksofstichill Posted August 1, 2013 Share Posted August 1, 2013 As per title we have come to a deal with Mountune to sell off the remainder of their stock of RS2000 parts at discounted prices. Everything is Brand New and unused, this is the last of there stock so once it's gone.....it's gone for good. None of this stock has ever been for sale to the general public until now, it was only ever available to works teams, etc. Firstly, a set of Cosworth 86.6mm Pistons complete with Goodgeon pins and rings so a complete package. Mountune RRP £1050, our price - £840 plus carriage at cost. 2 sets currently available. http://blackengineering.co.uk/images/Mountune/Cosworth-Pistons-1.JPG Group N Investment Casting Conrods - £600 plus carriage at cost. Only 1 set available http://blackengineering.co.uk/images/Mountune/Group-N-Conrods-1.JPG Alloy Thermostat Housing - £75 each plus carriage at cost. All Sold but may be remade if there is any interest? http://blackengineering.co.uk/images/Mountune/Thermostat-Housings-1.JPG http://blackengineering.co.uk/images/Mountune/Thermostat-Housings-2.JPG Crankshaft Pulley complete - Mountune RRP £115.15, Our Price £92.12 plus Carriage at cost. Only 1 available 7mm Stem Kit Car Spec Inlet Valve, Single Groove retainers wasted stem - Mountune RRP £46.84 each, Our Price £37.47 each plus Carriage at cost. 19 Available 7mm Stem Kit Car Spec Exhaust Valve - Mountune RRP £46.84 each, Our Price £37.47 each plus Carriage at cost. 18 Available Retainers/Collets for 7mm Valves - Mountune RRP £21.37 each, Our Price £17.10 each plus Carriage at cost. 64 available. Standard 3 Groove Inlet Valves - Mountune RRP £20.94 each, Our Price £16.75 each plus Carriage at cost. 18 Available. http://blackengineering.co.uk/images/Mountune/Mountune-Various-1.JPG New Alloy Upper Timing Covers, Mountune RRP £46.44 each, our price £37.15 each plus Carriage at cost. 4 Available, one pictured has an extra hole in it but the rest have got no extra hole as per standard and shown in the second photo. http://blackengineering.co.uk/images/Mountune/Alloy-Upper-Cover-1.JPG http://blackengineering.co.uk/images/Mountune/Alloy-Upper-Cover-2.JPG New 909 F2 Conrod Bearing Kit, Mountune RRP £230.40 each, our price £184.32 each plus Carriage at cost. 3 available. http://blackengineering.co.uk/images/Mountune/909-Bearings-1.JPG New 909 Cam Blanks, currently unground. Price to be confirmed, we are loooking to offer these cams ground to whatever mountune profile is required. Only 1 Pair available. http://blackengineering.co.uk/images/Mountune/909-Cam-1.JPG New Weber/Webcon Top Feed injectors WFI 031/IW031 270cc. Webcon RRP £160.96 each, Our Price £75 each so less than half price. 6 Available, these are no longer manufactured by Webcon. Details here - http://www.webcon.co.uk/shop/shopexd.asp?id=12676 http://blackengineering.co.uk/images/Mountune/Injector-1.JPG Spring Platforms. Mountune RRP £7.19 each, Our Price £5.75 each. 31 Available TDC Sensor. Mountune RRP £21.10 each, Our Price £16.88 each. 2 Available Standard Big End Bolts. Mountune RRP £4.20 each, Our Price £3.36 each. 33 Available Oil Gallery Bungs. Mountune RRP £1.08 each, Our Price £0.86 each. 9 Available Standard Main Cap Bolts. Mountune RRP £4.86 each, Our Price £3.89 each. 6 Available Collets, finis 1072051. Mountune RRP £2.28 each, Our Price £1.82 each. 10 Available Crank Pulley Bolt. Mountune RRP £6.25 each, Our Price £5.00 each. 3 Available Head Bolts. Mountune RRP £8.52 each, Our Price £6.82 each. 5 Available Main Cap Studs. Mountune RRP £4.62 each, Our Price £3.70 each. 6 Available Dowel Bushes, finis 6640936. Mountune RRP £2.10 each, Our Price £1.68 each. 23 Available Woodruff Key. Mountune RRP £2.10 each, Our Price £1.68 each. 17 Available Bung?. Mountune RRP £1.08 each, Our Price £0.86 each. 3 Available Oil Filter Arm Adaptor. Mountune RRP £40.55 each, Our Price £32.44 each. 1 Available V-Rated Big End Bolts. Mountune RRP £13.52 each, Our Price £10.82 each. 10 Available Valve Stem Oil Seal. Mountune RRP £1.08 each, Our Price £0.86 each. 85 Available Trumpet O-Ring. Mountune RRP £1.80 each, Our Price £1.44 each. 2 Available PME Trumpet for F2 Kit Car. Mountune RRP £160.00 each, Our Price £128.00 each. 1 Available Inlet Valve Seat for Titanium Valve. Mountune RRP £13.14 each, Our Price £10.51 each. 10 Available Exhaust Valve Seat for Titanium Valve. Mountune RRP £12.16 each, Our Price £9.73 each. 10 Available Valve Guide 6mm E003/0058/0. Mountune RRP £17.46 each, Our Price £13.97 each. 22 Available Special Valve Springs (Uprated Double Springs). Mountune RRP £39.37 each, Our Price £31.50 each. 14 Available Special Valve Spring Platforms. Mountune RRP £9.86 each, Our Price £7.89 each. 46 Available Piston Ring (Oil x 3). Mountune RRP £7.79 each, Our Price £6.23 each. 8 Available Piston Ring (Second). Mountune RRP £7.30 each, Our Price £5.84 each. 8 Available Piston Ring (Top). Mountune RRP £9.60 each, Our Price £7.68 each. 44 Available Followers for 7mm Valves Kit Car Spec. Mountune RRP £21.60 each, Our Price £17.28 each. 1 Available Spring Tensioner, finis no 6176569. Mountune RRP £1.56 each, Our Price £1.25 each. 2 Available Omega F2 Spec Pistons complete with Rings, Pins and Clips to suit standard 86.0mm bore as per FIA regs. Approx 12.5:1 Compression Ratio with a skimmed head. Mountune RRP £760.75 per set, Our Price £608.60 per set plus Carriage at cost. Only 1 Set available http://blackengineering.co.uk/images/Mountune/Omega-Pistons-1.JPG Also, same spec as above but Manufactured by Cosworth. Only 2 pistons available so a half set unfortunately. Mountune RRP £380.38 for the pair, Our Price £304.30 for the pair. As above, this is only 2 pistons, not a complete set of 4. Flywheel Bolts RRP £2.10 each, Our Price £1.50 each plus carriage at cost. Only 4 available now Genuine Ford Exhaust Gaskets (not all metal ones but Fibre one side and metal on the other side). £12 each plus carriage at cost. 6 Available Exhaust Gasket, one side - http://blackengineering.co.uk/images/Mountune/Exhaust-Gasket-1.JPG And the other side - http://blackengineering.co.uk/images/Mountune/Exhaust-Gasket-2.JPG Woodruff Keys, Studs, etc - http://blackengineering.co.uk/images/Mountune/Woodruff-Keys-1.JPG Any questions please just ask, I'm located near Kelso in the Scottish Borders but delivery can be arranged anywhere in the UK or worldwide. Cheers! Gary Link to comment Share on other sites More sharing options...
blacksofstichill Posted January 6, 2014 Author Share Posted January 6, 2014 Just to update this, many of the parts are now sold but the following are still available - Cosworth 86.6mm Pistons complete with pins and rings so a complete package. Mountune RRP £1050, our price - £840 plus carriage at cost. 2 sets currently available. Reduced: 90% of original size [ 800 x 588 ] - Click to view full imagehttp://blackengineering.co.uk/images/Mountune/Cosworth-Pistons-1.JPG Group N Investment Casting Conrods - £600 plus carriage at cost. Only 1 set available Reduced: 90% of original size [ 800 x 600 ] - Click to view full imagehttp://blackengineering.co.uk/images/Mountune/Group-N-Conrods-1.JPG Crankshaft Pulley complete - Mountune RRP £115.15, Our Price £92.12 plus Carriage at cost. Only 1 available 7mm Stem Kit Car Spec Inlet Valve, Single Groove retainers wasted stem - Mountune RRP £46.84 each, Our Price £37.47 each plus Carriage at cost. 11 Available 7mm Stem Kit Car Spec Exhaust Valve - Mountune RRP £46.84 each, Our Price £37.47 each plus Carriage at cost. 10 Available Retainers/Collets for 7mm Valves - Mountune RRP £21.37 each, Our Price £17.10 each plus Carriage at cost. 48 available. Standard 3 Groove Inlet Valves - Mountune RRP £20.94 each, Our Price £16.75 each plus Carriage at cost. 18 Available. http://blackengineering.co.uk/images/Mountune/Mountune-Various-1.JPG New Alloy Upper Timing Covers, Mountune RRP £46.44 each, our price £37.15 each plus Carriage at cost. 3 Available, one pictured has an extra hole in it but the rest have got no extra hole as per standard and shown in the second photo. Reduced: 56% of original size [ 1280 x 960 ] - Click to view full imagehttp://blackengineering.co.uk/images/Mountune/Alloy-Upper-Cover-1.JPG http://blackengineering.co.uk/images/Mountune/Alloy-Upper-Cover-2.JPG New 909 F2 Conrod Bearing Kit, Mountune RRP £230.40 each, our price £184.32 each plus Carriage at cost. 3 available. http://blackengineering.co.uk/images/Mountune/909-Bearings-1.JPG New 909 Cam Blanks, currently unground. Price to be confirmed, we are loooking to offer these cams ground to whatever mountune profile is required. Only 1 Pair available. http://blackengineering.co.uk/images/Mountune/909-Cam-1.JPG Spring Platforms. Mountune RRP £7.19 each, Our Price £5.75 each. 31 Available TDC Sensor. Mountune RRP £21.10 each, Our Price £16.88 each. 2 Available Standard Big End Bolts. Mountune RRP £4.20 each, Our Price £3.36 each. 33 Available Oil Gallery Bungs. Mountune RRP £1.08 each, Our Price £0.86 each. 9 Available Standard Main Cap Bolts. Mountune RRP £4.86 each, Our Price £3.89 each. 6 Available Collets, finis 1072051. Mountune RRP £2.28 each, Our Price £1.82 each. 10 Available Crank Pulley Bolt. Mountune RRP £6.25 each, Our Price £5.00 each. 3 Available Head Bolts. Mountune RRP £8.52 each, Our Price £6.82 each. 5 Available Main Cap Studs. Mountune RRP £4.62 each, Our Price £3.70 each. 6 Available Dowel Bushes, finis 6640936. Mountune RRP £2.10 each, Our Price £1.68 each. 23 Available Woodruff Key. Mountune RRP £2.10 each, Our Price £1.68 each. 17 Available Bung?. Mountune RRP £1.08 each, Our Price £0.86 each. 3 Available Oil Filter Arm Adaptor. Mountune RRP £40.55 each, Our Price £32.44 each. 1 Available V-Rated Big End Bolts. Mountune RRP £13.52 each, Our Price £10.82 each. 10 Available Valve Stem Oil Seal. Mountune RRP £1.08 each, Our Price £0.86 each. 85 Available Trumpet O-Ring. Mountune RRP £1.80 each, Our Price £1.44 each. 2 Available Inlet Valve Seat for Titanium Valve. Mountune RRP £13.14 each, Our Price £10.51 each. 10 Available Exhaust Valve Seat for Titanium Valve. Mountune RRP £12.16 each, Our Price £9.73 each. 10 Available Valve Guide 6mm E003/0058/0. Mountune RRP £17.46 each, Our Price £13.97 each. 22 Available Special Valve Springs (Uprated Double Springs). Mountune RRP £39.37 each, Our Price £31.50 each. 14 Available Special Valve Spring Platforms. Mountune RRP £9.86 each, Our Price £7.89 each. 46 Available Piston Ring (Oil x 3). Mountune RRP £7.79 each, Our Price £6.23 each. 8 Available Piston Ring (Second). Mountune RRP £7.30 each, Our Price £5.84 each. 8 Available Piston Ring (Top). Mountune RRP £9.60 each, Our Price £7.68 each. 44 Available Omega F2 Spec Pistons complete with Rings, Pins and Clips to suit standard 86.0mm bore as per FIA regs. Approx 12.5:1 Compression Ratio with a skimmed head. Mountune RRP £760.75 per set, Our Price £608.60 per set plus Carriage at cost. Only 1 Set available http://blackengineering.co.uk/images/Mountune/Omega-Pistons-1.JPG Also, same spec as above but Manufactured by Cosworth. Only 2 pistons available so a half set unfortunately. Mountune RRP £380.38 for the pair, Our Price £304.30 for the pair. As above, this is only 2 pistons, not a complete set of 4. Link to comment Share on other sites More sharing options...
Stu Posted January 6, 2014 Share Posted January 6, 2014 Out of interest, what CH and pin size are those pistons? Link to comment Share on other sites More sharing options...
