Warwick Posted September 13, 2003 Share Posted September 13, 2003 at the moment i have a 1.4 LX carb CVH orion just wandering if i could get a 1.6i Ghia in there instead Link to comment Share on other sites More sharing options...
Markt8 Posted September 13, 2003 Share Posted September 13, 2003 at the moment i have a 1.4 LX carb CVH orion just wandering if i could get a 1.6i Ghia in there instead If its a standard CVH then u can only replace it with a CVH or the car will need an ECU wired in and the fuel tank replaced if its an EFi, iv just dropped my car off to get a 1.4CVH installed and im dropping from a 1.6CVH and i was gonna go for a 1.6Efi but the work apparently is a lot Link to comment Share on other sites More sharing options...
sortedford Posted September 13, 2003 Share Posted September 13, 2003 y go to a smaller engine Link to comment Share on other sites More sharing options...
900ss Posted September 13, 2003 Share Posted September 13, 2003 EFi would be the expensive option imo. You might aswell just go for a straight 1.6 carbed CVH engine, that would drop straight in. Link to comment Share on other sites More sharing options...
Tythman Posted September 14, 2003 Share Posted September 14, 2003 Ive got a CFi. How does that differ from the CVH and EFi!? Link to comment Share on other sites More sharing options...
900ss Posted September 14, 2003 Share Posted September 14, 2003 TythmanCfi is only a name given to a particular type of injection system.Basically your engine uses one single point injector unit (cfi) so it only uses 1 main injector unit to feed all four cylinders, tis very similar in appearance to a carb as it goes.A multipoint injection system (efi) uses multiple injectors, normally one per cylinder - so a four cylinder engine would normally have four separate injectors. Link to comment Share on other sites More sharing options...
Tythman Posted September 14, 2003 Share Posted September 14, 2003 Can i upgrade from a CFi to an EFi? Link to comment Share on other sites More sharing options...
900ss Posted September 14, 2003 Share Posted September 14, 2003 You could but there's no point imo, the cost n bits involved would make it to expensive n the rewards would be next to zero.Fitting a 1.6 cvh would be the easiest option imo n to look at no one would be any the wiser (unless you know where to look) Link to comment Share on other sites More sharing options...
Warwick Posted September 14, 2003 Author Share Posted September 14, 2003 Wat has the 1.6 carb engine in Link to comment Share on other sites More sharing options...
Warwick Posted September 14, 2003 Author Share Posted September 14, 2003 plus wats the stat for a 1.6 carb (bhp, fuel consumption etc) anyone know Link to comment Share on other sites More sharing options...
900ss Posted September 14, 2003 Share Posted September 14, 2003 Wat has the 1.6 carb engine in The very last of the mk4 escorts had a 1.6cvh that should be suitable aswell as the early mk5’s, both as far as I can rem would interchange with each other. Link to comment Share on other sites More sharing options...
Warwick Posted September 15, 2003 Author Share Posted September 15, 2003 cheers m8 for ur help Link to comment Share on other sites More sharing options...
