davec Posted October 21, 2014 Share Posted October 21, 2014 I've just removed the fusebox on my MK6 to try and solve an issue with the rear screen heater.Connected it back up and the starter wouldn't operate on the key.Checked plugs etc, wiring and feed going to R13,feed and switch feed both there.If I turn ignition key to start and push in R13 the car turns over but doesn't start.I've also noticed that when I turn the ignition on the LED below the clock no longer comes on.Anyone with any thoughts much appreciated. Link to comment Share on other sites More sharing options...
Mex Posted October 21, 2014 Share Posted October 21, 2014 Are all the connectors fully inserted in the fusebox? Link to comment Share on other sites More sharing options...
davec Posted October 21, 2014 Author Share Posted October 21, 2014 I've checked all connections,relays etc and all seem ok.I marked everything I removed in order to put everything back as it was.Everything works except the rear screen still,so all this hassle for nothing gained.Nothing at all on start-up,usually you hear what I think is fuel pump,but I've noticed the LED no longer illuminates under the clock when ignition is turned on. It's got to be something stupidAny ideas would be much appreciated as I'm stumped. Link to comment Share on other sites More sharing options...
demented Posted October 21, 2014 Share Posted October 21, 2014 I believe on the Mk 6 fuse box, to the rear & maybe underneath, there are two plugs which look identical and can be inserted into each other socket/receptical: maybe these plus have been inserted into the wrong sockets ? As for the heated rear screen; if a hatchback, it could be due to the tailgate losing its Earth at the hinges due to wear or maybe rust ? I ran a new Earth wire from the Earth of the rear fog light and bolted it to the Earth of the tailgate actuator; since doing so all the electrical issues I was experiencing with the tailgate have been resolved. Link to comment Share on other sites More sharing options...
davec Posted October 21, 2014 Author Share Posted October 21, 2014 Thanks very much for your reply,i'll check in the morning.Regarding the heater,you can hear the relay pull in but no output.Nothing on the tailgate contact plate and nothing on the switch indictor to say it's on.I've changed the relay as well. Link to comment Share on other sites More sharing options...
davec Posted October 22, 2014 Author Share Posted October 22, 2014 Could someone tell me what the R2 Brown relay is please,i'm trying to identify it in the Haynes manuel.If I short the terminals out the car will start,but there is no feed to the coil.Thanks Link to comment Share on other sites More sharing options...
davec Posted October 22, 2014 Author Share Posted October 22, 2014 It looks like R2 feeds R3,fuel pump relay.The contacts on R2,one side fed direct from the battery if shorted out operate the fuel pump,light under clock and the engine turns over and starts.I removed the fuse box and traced where the coil connections went to.One side went to earth,which checked out ok and the other side went to the large multiplug at the rear of the box,to try and find why R2 wasn't pulling in.This is where the plot thickens,when checking this connection,their was no wire in the multiplug???????I've ended up running a wire from the ignition switch to feed R2 coil+ and the car now runs.If anyone can explain this I'd appreciate it. Link to comment Share on other sites More sharing options...
