ploppy Posted May 24, 2005 Share Posted May 24, 2005 firstly i would like to transfer the top half of a 2l onto my 1.8 block. top half including, head, tb, cams, manifolds etc.the next question is what air filter to use, do i use a panel filter, or do i use an induction kit? please help. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 24, 2005 Share Posted May 24, 2005 This one!! Very good proven results on many cars. Link to comment Share on other sites More sharing options...
Pricey Posted May 24, 2005 Share Posted May 24, 2005 Ive had a KN57i kit for years and i thought i would try the KN panel filter and it seems to rev alot smoother and is better on fuel Link to comment Share on other sites More sharing options...
tidykart Posted May 24, 2005 Share Posted May 24, 2005 You cheeky git 'Ex-Finesse'. This debate has roared on for ages, No this is the best one, the Viper, sounds lush, has definetly given my GTi a boost and made her a lot smoother. Link to comment Share on other sites More sharing options...
Rob84 Posted May 24, 2005 Share Posted May 24, 2005 K&N 57i every time Link to comment Share on other sites More sharing options...
M4TT Posted May 24, 2005 Share Posted May 24, 2005 (edited) i had K&N 57i on my old car but i do like a drill airbox with a K&N panel filter better Edited May 24, 2005 by M4TT Link to comment Share on other sites More sharing options...
Mike C Posted May 24, 2005 Share Posted May 24, 2005 Viper, no contest Link to comment Share on other sites More sharing options...
ScORTED Posted May 24, 2005 Share Posted May 24, 2005 got a panel filter for sale for the zetec airboxes... boxed and oiled as new Link to comment Share on other sites More sharing options...
ploppy Posted May 25, 2005 Author Share Posted May 25, 2005 how much? Link to comment Share on other sites More sharing options...
ploppy Posted May 25, 2005 Author Share Posted May 25, 2005 so wot one would be easier to get the correct fueling from. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 25, 2005 Share Posted May 25, 2005 Your MAF will sort the fueling. Link to comment Share on other sites More sharing options...
ploppy Posted May 25, 2005 Author Share Posted May 25, 2005 i heard many a induction before and they often sound the balls. will iget a difference in sound from a panel filter considering the air box was designed to keep noise to a minimum. i used a universal induction kit on my 1800 and 1600. both used the same kit. it sounded the balls on my 1800 but didnt run that nicely. Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 25, 2005 Share Posted May 25, 2005 it sounded the balls on my 1800 but didnt run that nicely.<{POST_SNAPBACK}>Sounds like you were sucking in hot air from the engine bay, which is the danger with induction kits that don't have a decent cold air feed. Buy my BMC, it's the best you'll get for the money, and I've never seen on on an escort Link to comment Share on other sites More sharing options...
Timmy C Posted May 25, 2005 Share Posted May 25, 2005 If you wanted as much power as possible from your induction kit you could buy ralphs (exfinesse) and set it up like this to have nice cold air forced down its throat. You dont have to do it like that with the light, just find some way of getting the inlet to the front of the car rather than just letting it hang out a bit below like the viper. Best posible combination would be a viper and a setup where the inlet is at the front!! Link to comment Share on other sites More sharing options...
Ex-Finesse Posted May 25, 2005 Share Posted May 25, 2005 If you wanted as much power as possible from your induction kit you could buy ralphs (exfinesse) and set it up like this to have nice cold air forced down its throat. <{POST_SNAPBACK}>Indeed.... One of the reasons I am selling is because this kit would fit beautifully if using a morette intake...... but I refuse to do that, so I'm changing kits. Sad really, I wanted one of these BMC's for ages - they really are the tits Link to comment Share on other sites More sharing options...
