sorted_mk6 Posted June 5, 2005 Share Posted June 5, 2005 right, tried startin my car after the engine conversion i did, it turns over but it just wont fire up, ive checked it and there aint any sparks from the plugs. i cant figure out why, there is power goin to the coil, and ive checked the resistance and all seems fine.im just stuck so anyone got any ideas wat i can try? or wat cud be the prob?any ideas wud be greatcheers Link to comment Share on other sites More sharing options...
ploppy Posted June 6, 2005 Share Posted June 6, 2005 get a cheapy coil pack down the breakers and then get new lleads and plugs. Link to comment Share on other sites More sharing options...
Muzz Posted June 6, 2005 Share Posted June 6, 2005 Did you change the ECU? Link to comment Share on other sites More sharing options...
RobMk6 Posted June 6, 2005 Share Posted June 6, 2005 been off for a while so enlighten me on the engine conversion??? Link to comment Share on other sites More sharing options...
sime73 Posted June 6, 2005 Share Posted June 6, 2005 if u changed the ecu wat did u do with the PATS ? could be your prob Link to comment Share on other sites More sharing options...
sorted_mk6 Posted June 6, 2005 Author Share Posted June 6, 2005 ive changed everythin, conversion is 1.3 endura e to 1.8 zetec xr3ii dont really understand all this PATS stuff, wat do u actually have to change?wudnt PATS stop everythin from workin tho, cos everythin seems to work apart from no sparks? its had pretty much everythin changed, got the 1.8 xr ecu on, but i havent changed the ignition barrel, wud this cause it, i have got a non-PATS ignition barrel but i cant see any differencecheers Link to comment Share on other sites More sharing options...
sorted_mk6 Posted June 6, 2005 Author Share Posted June 6, 2005 also should the codes on the ecu and ignition module be the same? or part of it match up? Link to comment Share on other sites More sharing options...
sorted_mk6 Posted June 7, 2005 Author Share Posted June 7, 2005 sorry to put this back to top but i still confused ppl Link to comment Share on other sites More sharing options...
RobMk6 Posted June 7, 2005 Share Posted June 7, 2005 ive changed everythin, conversion is 1.3 endura e to 1.8 zetec xr3ii dont really understand all this PATS stuff, wat do u actually have to change?wudnt PATS stop everythin from workin tho, cos everythin seems to work apart from no sparks? its had pretty much everythin changed, got the 1.8 xr ecu on, but i havent changed the ignition barrel, wud this cause it, i have got a non-PATS ignition barrel but i cant see any differencecheers<{POST_SNAPBACK}> in that case its nowt to do with the PATS just check all connections and see if you can get an ECU from anywhere else to test Link to comment Share on other sites More sharing options...
