marcus Posted June 6, 2005 Share Posted June 6, 2005 when i turn the ignition, the fuel pump primes BUT (i have a fuel pressure gauge) and the fuel pressure goes up as it usually does but then it goes straight down to 0 again. when i start the car, it seems hesitant and it has cut out on me 3 times today anybody have a clue what it is??? im thinking fuel pump??? Link to comment Share on other sites More sharing options...
DAVE W Posted June 6, 2005 Share Posted June 6, 2005 Wont it be because you avent got your unichip and running it off your 1.6 ECU Link to comment Share on other sites More sharing options...
ploppy Posted June 6, 2005 Share Posted June 6, 2005 blocked fuel fitler? Link to comment Share on other sites More sharing options...
marcus Posted June 6, 2005 Author Share Posted June 6, 2005 oooh, ill try the fuel filter. no dave, it wont cos it only started doing it yesterday Link to comment Share on other sites More sharing options...
Rob84 Posted June 6, 2005 Share Posted June 6, 2005 fuel pumps on them a re a swine to do, tank out jobbie, the lot and are expensive. iahd mine replaced on the mk6 and paid around £200 iirc Link to comment Share on other sites More sharing options...
Lee R Posted June 6, 2005 Share Posted June 6, 2005 you've upset the car by taking the stickers off. Link to comment Share on other sites More sharing options...
marcus Posted June 6, 2005 Author Share Posted June 6, 2005 you've upset the car by taking the stickers off. <{POST_SNAPBACK}> nooooo, it was much faster cos there is less weight on it now, its like a propper track car Link to comment Share on other sites More sharing options...
Lee R Posted June 6, 2005 Share Posted June 6, 2005 you've upset the car by taking the stickers off. <{POST_SNAPBACK}> nooooo, it was much faster cos there is less weight on it now, its like a propper track car <{POST_SNAPBACK}> bringing it to bruntingthorpe track day then? Link to comment Share on other sites More sharing options...
marcus Posted June 6, 2005 Author Share Posted June 6, 2005 you've upset the car by taking the stickers off. <{POST_SNAPBACK}> nooooo, it was much faster cos there is less weight on it now, its like a propper track car <{POST_SNAPBACK}> bringing it to bruntingthorpe track day then? <{POST_SNAPBACK}> depends, might do cos im lookin into gettin maxin out another card an gettin a chip next week Link to comment Share on other sites More sharing options...
Lee R Posted June 6, 2005 Share Posted June 6, 2005 you've upset the car by taking the stickers off. <{POST_SNAPBACK}> nooooo, it was much faster cos there is less weight on it now, its like a propper track car <{POST_SNAPBACK}> bringing it to bruntingthorpe track day then? <{POST_SNAPBACK}> depends, might do cos im lookin into gettin maxin out another card an gettin a chip next week <{POST_SNAPBACK}> do it Link to comment Share on other sites More sharing options...
sime73 Posted June 6, 2005 Share Posted June 6, 2005 does the pressure drop as soon as the pump stops priming?? fuel regulator ?leak ?fuel pump relay? Link to comment Share on other sites More sharing options...
marcus Posted June 6, 2005 Author Share Posted June 6, 2005 dont think itll b the regulator as i have a pbwer boost vavle not a leak, ive looked everywhere an the petrol aint goin down the fuel pump relay, i was thinking this because my dad put his ear near the fuse box and a relay clicked when the ignition was turned on an the fuel pump primed but then it clicked again when the fuel pump turned off an the pressure goes down, dad seems to think that the relay should remain open once the ignition is on an not click off like it is doing Link to comment Share on other sites More sharing options...
sime73 Posted June 6, 2005 Share Posted June 6, 2005 dont think itll b the regulator as i have a pbwer boost vavle not a leak, ive looked everywhere an the petrol aint goin down the fuel pump relay, i was thinking this because my dad put his ear near the fuse box and a relay clicked when the ignition was turned on an the fuel pump primed but then it clicked again when the fuel pump turned off an the pressure goes down, dad seems to think that the relay should remain open once the ignition is on an not click off like it is doing<{POST_SNAPBACK}> well maybe the boost valve is faulty the relay should power the pump for a sec or so to prime the system then power off, then wen u turn the engine over it should power on again and stay on if the engine starts Link to comment Share on other sites More sharing options...
marcus Posted June 6, 2005 Author Share Posted June 6, 2005 how do i tell if the PBV is fooked, is there an easy way??? i could put the origional fuel regulator on but i cut the fuel line an got no way of joinin it back up again Link to comment Share on other sites More sharing options...
plumber60 Posted June 6, 2005 Share Posted June 6, 2005 how do i tell if the PBV is fooked, is there an easy way???<{POST_SNAPBACK}>the only problem ive seen and heard on a PBV is a Blown gasket, it makes a whining noise and the car underfueled, it was my mates GT4 ST185 Link to comment Share on other sites More sharing options...
