Devboy Posted June 19, 2005 Share Posted June 19, 2005 Ok, so i got my drapper cam locking tool today for my car, went to put it on and the cams are sitting to low! the bar flat on the cyclinder head will not slide into the lines on the cams for the locking tool!! why? is this a problem with my engine or the tool? I have turned the cams 180' but then they sit even lower!?!?!?!?!?!?!? Link to comment Share on other sites More sharing options...
geordie_aaron Posted June 19, 2005 Share Posted June 19, 2005 have sombody play with the crankshaft 4ward and back while your TAPPING the block in, it defo goes in just needs some purwation (BIG gspelling lol) Link to comment Share on other sites More sharing options...
Devboy Posted June 19, 2005 Author Share Posted June 19, 2005 tapping the block? umm what! i did have someone turning the wheel and it wasnt having any of it! Link to comment Share on other sites More sharing options...
simonh1 Posted June 20, 2005 Share Posted June 20, 2005 You really don't need it if you are very careful, and move the cams to the correct position against the force of the valve springs as you put your new belt on so as to make sure the teeth are aligned correctly. Link to comment Share on other sites More sharing options...
ANDYC Posted June 20, 2005 Share Posted June 20, 2005 if they are sitting to low you have the engine 180degrees out turn the crank another turn and itll be ok Link to comment Share on other sites More sharing options...
